Question about Yahoo Messenger
My audibles in yahoo messenger didnt work..:(
At first, i can send and receive audibles as usually.but suddenly,i cannot sent them! i can receive,n i still have d audibles in my toolbars,when i sent it,,it appears on my window,,but not in receiver's window..why do this happened?what should i do to make it works again?
  • genovaive_c Mar 18, 2009
    i can send audibles..but i cant see them in my environment after sending...also, i cant hear or see the audibles that was sent to me...what shall i do?
4 Suggested Answers
  • 2642 Answers
SOURCE: the dialogue box on yahoo messenger does not show messages
The problem is probably with the support software that drives Messenger - this is not downloaded with Yahoo Messenger but installed on your computer. Check your IE settings first
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Posted on Aug 31, 2009
manishsh
  • 269 Answers
SOURCE: reinstallation of yahoo messenger
download yahoo messenger stand alone version from here
select your country then download
http://www.mydigitallife.info/2009/11/16/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/
Regards
manish
Posted on Mar 22, 2010
  • 2291 Answers
SOURCE: Yahoo messenger.exe - application error
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Posted on Jan 31, 2011
sweetnove373
  • 19 Answers
SOURCE: In yahoo messenger in chat
Try to follow these few steps, & you should be okay =)
1) Go to "Run". You can click the start bar, then type "run" in the search bar, the application should pop-up right after that.
2) In the "Run" interface, type "regedit", & a window says "Registry Editor" should come out after that.
3) Okay, now pay attention because this is where we get the tricks done. In the "Registry Editor" panel, look for "HKEY_CURRENT_USER". Expand it.
4) From there (expanded HKEY_CURRENT_USER) & now on, expand all the way according to these order: --> Software --> Microsoft --> Windows --> CurrentVersion --> Internet Settings --> Zones.
5) In "Zones", there should be consist ONLY with "0,1,2,3,4" accordingly. Anything besides those numbers, DELETE it. Close the "Registry Editor".
6) Now you can try opening your YM. & tadaaaa!... It's back to normal.
Posted on Jun 03, 2011
Testimonial: "It was great ... nice solution thanks a million "
No audibles in yahoo messenger
Once you signed in to your Yahoo!Messenger, choose the person you want to chat. When the chat box appeared, click on the view tab then check the Audibles Toolbar.. Now, you can send Audibles.. =)
May 27, 2011 | Computers & Internet
I cant see my chat writing
Same problem here:(
All the old (received) messages windows look blank and also the text i am writing in a active chat window
Audibles also don't show image or have sound...
Only text i can see are my messages before being sent and the received messages only for a few seconds in the "Info/Alert Bubble' close to the Tray...
Uninstaled and reinstalled different 4 versions: 9.x, two versions of YM 10,
and latest beta version 11
All have same behavior!
Anyone can help us?
Mar 15, 2011 | Yahoo Messenger
No sound from audables
If you want to activate the sounds for your audibles follow this link
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/entertainment/mstaauds.html
There are instances that audibles will not function because you have no flash player install in your computer. If you wanted to use your audibles and see all its features then install flash player. Save this file and install it.
Adobe Flash Player
Let me know if your audibles did make a sound every time you receive and send messages. Please comeback and give me some ratings. Thank You for using Fixya.
May 31, 2010 | Yahoo Messenger
I cant see text when chatting on yahoo messenger. It has been working well until today.
I had the same problem.
Luckyly I found an easy solution.
Close yahoo messenger
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
After that everything worked smoothly.
jomahali (at) hotmail.com
Oct 13, 2009 | Yahoo Messenger
My Yahoo Has stops randomly
Try uninstalling and reinstalling your downloaded messenger, then completley sign out of yahoo network and do a basic cleanup on your computer (cookies, temp files, etc.) for the web version.
Mar 31, 2009 | Yahoo Messenger
Cannot access any links sent to IM!
you might have to reinstall the yahoo messenger again.this is an installation error.If the problem persists, then try downloading yahoo messenger from the direct website or from the link given below.
yahoo messenger downloadable here
Dec 18, 2008 | Yahoo Messenger
When using yahoo messenger, why doesn't anything I send or receive in an instant message get displayed?
this could happen if you have the latest version of ym on your computer and the one you're sending messages to has the old version, make sure both of you are using the latest version of ym
download
Oct 24, 2008 | Yahoo Messenger
Can't Send Messages
help..
my yahoo messenger won't show any messages on the IM window. I can see what i am typing but not when i've sent it already. I can't also see the messages sent for me. I've already reinstall different versions of yahoo messenger and have followed the instructions to troubleshoot it but it still doesn't work.
thank you
Sep 15, 2008 | Yahoo Messenger
Matter that we sent in Yahoo messenger,yahoo mail in ie6 not visible
try pressing F11. You are using the new yahoo mail interface right?
Sep 23, 2007 | Microsoft Windows Xp Home Edition English...
Yahoo messenger
That happened to me when I was on dial up so painstakingly I uninstall the whole lot and then started again. I reinstalled Yahoo messenger 8.1 and it took over and hour to do the install but it paid off. All the extras ie; audibles all worked again and this time guess what it came with all the new audibles included were Chinese and Indian(hindu) audibles not that I would use them I suppose but who knows who might come to dinner and use MY yahoo!!!....good luck pal. OH yeah in case your interested yahoo have a web page now that you can log into anywhere in the world with your yahoo ID without having to download anything just try it go here http://au.webmessenger.yahoo.com
Sep 05, 2007 | Microsoft Office Outlook 2003 for PC
Yahoo Messenger Logo
337 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
