Question about Refrigerators
Ge refrigerator is not cold enough and ice is not working
Freezer is not cold enough to freeze, ice is not working, but water is working, I can feel ice in machine, but most of my food is not frozen or semi frozen. Refrigerator part feels warmer also, not as cold as usual. Motor does run, feel cool air coming out of vents, but not enough to keep cold.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Nov 27, 2012
  • 2 more comments
  • Melissa Whitman Nov 27, 2012
    GE Side by Side Model No TPXX24BRDA... Freezer is keeping things cold but not frozen and no ice so that makes sense if its not cold enough. We just cleaned out the coils. Its about ten years old. ALways worked great. No ice build up at all anywhere.
  • Richard Roth
    Richard Roth Nov 27, 2012
    OK, first pull the unit out from the wall and make sure the condenser coils and fan are clean from any lint buildup. If that is OK, then you will need to replace the cold control. Here is the part to order.http://bit.ly/Uas8vY
  • Melissa Whitman Nov 28, 2012
    Okay we did pull it out and cleaned out the condenser coils. They were a mess! How do you replace the cold control? Are you local or can you suggest someone local? My refrigerator has the wood grain panels built on top of it to match the cabinets so we really want to save it if possible. Thanks SO much for your help!
  • Richard Roth
    Richard Roth Nov 28, 2012
    OK, if it was really dirty, give it a day and see how it runs. 80% of the time with the type of problem that you are having is from dirty coils. I don't know where you live but I am in New Orleans. If you tell me where you are located I will check with my supplier and find a reputable service tech. But I am sure we can work thru it together. Also, if you should need me and I am not on FixYa you can get me thru my new website athttp://appliancecafe.com and use the contact form or the repair forum from the links on top of my page.
SOURCE: Side by Side Can't find model # Not cooling enough
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Posted on Jul 06, 2008
  • 10 Answers
SOURCE: Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
I had a similar problem where the refrigerator side was not cooling well but I could feel very little air coming through the vent in the top left corner.I blew hot air from a blow driver into the vent for about 1 minute which melted ice that was hanging from the bottom of the vent cover.Cold air started blowing harder thru the vent and cured the problem.
Posted on Feb 16, 2009
  • 531 Answers
SOURCE: Refrigerator warm, freezer is fine.
you have defrost problem
Posted on Apr 06, 2009
erpaalai
  • 999 Answers
SOURCE: Refrigerator is not cool
First you need to measure the temp in the frig. Place a thermometer in a glass of water overnight or in a jar of pickles. If the temp is not below 40 deg F it is too warm. It could be anything from the fan running too slow, to frost buildup due to failed or failing components in the defrost circuit. If the thermostat is all the way up and everything else is working properly it could be the thermostat. Make sure nothing is blocking the places where the air enters and exits th refrigerator from the freezer. Please let me know what you find.....Eric
Posted on Jun 09, 2009
  • 97 Answers
SOURCE: GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Posted on Jun 10, 2009
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
GE refrigerator / Freezer - Erratic freezing
Oct 22, 2012 | GE Refrigerators
Refrigerator not cold enough but freezer still freezing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The freezer is not cold enough to freeze nor is the temperature in the whole refrigerator cold.
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
Feb 01, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Our freezer does not seem to be freezing cold enough. When the ice maker is turned on it freezes water down inside.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
