Question about Saws
My moter humms, the blade wont trun on my tile wet saw, for cutting ceramic tile
When i turn on the wet saw for cutting tile, the motor hums, but the shaft and blade wont turn and the motor gets warm quick
thabrain
  • 76 Answers
SOURCE: Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Posted on Nov 05, 2008
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
woobie dog
  • 1273 Answers
SOURCE: I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
Posted on Nov 10, 2009
  • 55 Answers
SOURCE: I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Posted on Dec 02, 2009
Wet saw is not cutting square, blade is new but once it hits the tile is shimmies.
Make sure you have the correct blade. There are different blades for different tile. ie ceramic blade for ceramic tile.
Dec 31, 2016 | Blade Saws
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
How do I take the cutting blade off a Mastercraft wet tile saw model #55-6829-4. I keep turning the ceramic like washer counter clock wise and it doesn't come off.
you have to stop the blade turning. Grip it with some locking pliers but it might damage the blade. Or jam it with a piece of wood/ stone and undo the nut.
Nov 23, 2010 | Saws
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
No problem: I need to know the specs of a ceramic tile cutting blade that will fit the Hitachi C7SC circular saw that I possess. Your machine is the best
Any blade 7 1/4" in diameter or smaller with a 5/8" arbor will fit on your saw. Your saw is capable of cutting tile but the dust that will be drawn into the saw by the fan will be very hard on your brushes, armature and bearings severly shortening it's life. Tile saw motors are usually sealed or made to work with water to keep the dust down. Don't use water with your saw, it's not grounded.
Aug 31, 2010 | Garden
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Saws Logo
47 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
