What is solution of one side fade print out in samsung 3201
I have Samsung SCX-3201 Printer. I have already took more than 2500 print with 2 times refill. but it now indicate Red light signal and not taking print. So what i have to d. and I need reset software.
actully when you will see the toner it have a chip on right side .
replace this chip and you will find solution .it is 1000% works
Navjot from super computers 9166620501
Jun 27, 2011 | Office Equipment & Supplies
Was told need new "drum assy" because of faded
sir/mam drum do go bad after so many copies and prints. normally machine will indicate when that is needed.
Mar 04, 2011 | Samsung Office Equipment & Supplies
PRINT IS FADED HALF THE PAGE IS FADED
Remove toner cartridge and tilt from side to side to redistribute toner. Easy fix to try and usually the correct one.
Apr 20, 2010 | Samsung CLP 300 Laser Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
The printing quality either in bw or color is not good
Very impotant to select type of using paper. Some thick or thin paper need to use special settings in menus of pinters. Please read user manual in chapter "working with paper". Use must use only original Samsung toner cartridges if you dont want to see faded on other side.
Dec 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Samsung SCX4216 MF
Called in a Samsung technician to fix/replace scanning unit
Oct 13, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Black partial fading
It's either the opc drum is on it's way out or the charge roller/corona wire faulty or needs cleaning
May 18, 2008 | Samsung CLP 300 Laser Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
k24674
