Question about Fuji FinePix F410 Digital Camera
White balance Hi I am having problems taking photos outdoors the images are coming out extra bright. I am told it is the white balance. Have tried auto/manual and different adjustments + and - but to no avail . With thanks Peter
  • Fuji Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
F303, F410, and F700
Posted on Dec 23, 2007
  • 23 Answers
White balance usually refers to color not brightness. a good way to test your white balance though is to take a sheet of paper and zoom in on it. if it's white, than the white balance isn't the issue. it's most likely lens aperture, though I dont have a clue how to change that on that model camera. if nothing else you at least know what to look for now. sorry i can't be more help. good luck
Posted on Jun 07, 2007
What would make my pictures and videos come out with a lot of blue tint?
Regarding Blue tint of Photos and Videos - This is tied directly to your White Balance Settings. When you White Balance is set to Auto, the Camera determines the best setting to use to for White Balance (How much Blue or Orange needs to be added for best White). To get a Blue Tint, the Camera's White Balance is most likely set manually to something like Incandescent or Indoor. First you will want to see that your White Balance is set to Auto - If it was not, then Auto should fix your problem. But If it is alrready on Auto, and you are still getting Blue tint both Indoor and Outdoor, then the Camera's Software may be faulty.
Hope this helps!
Jan 12, 2016 | Cameras
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Dec 02, 2015 | Olympus FE-340 Digital Camera
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Colour balance for majority of photo is good but sky or white goes to pink. Colour balance is obviously not the problem. Help?
How about White Balance? Taking a photo outdoors, for example, white your WB is set on "Fluorescent Light" will turn your images bluish. To set WB, see the owners manual.
Jun 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Colour tone issues with Fujifilm Finepix S5700
It sounds like the sepia tone is most likely caused by the tungsten lights in a regular room. Without flash, the only source of illumination indoors is artificial light (unless window light is dominant). There is a way to color balance the camera to approximate sunlight through the manual settings. Look in the menus for "white balance". You'll need to take the camera off of the fully automatic settings first. Move the cursor up or down while looking at the image and you will see the color shift. when you find a color balance you like for that particular room's lighting conditions, hit the OK to lock it in the activated position. Remember to go back to "auto" white balance for most shooting, especially outdoors, or everything will take on a wierd color cast.
Jun 03, 2008 | Cameras
Canon Powershot S330 Picture Brightness Help!!!
It sounds like the camera exposure system is out of whack and may need to be serviced. You may want to ensure that exposure compensation is set to 0. Check one of your overexposed images with the display in the 'Detailed Display' mode (two lines of information at the bottom of the LCD). If the second item on the top line is not ±0, the exposure compensation is not at its default value. To set, put the camera in M(anual) shooting mode. Press the Exposure/White Balance button until you see a scale along the bottom of the LCD from -2 to +2. Use the left or right button to set it at 0. If the value is already at 0, you will probably need service.
Apr 28, 2008 | Canon PowerShot S330 / IXUS 330 Digital...
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
Pictures are too bright when shooting outdoors in sunlight
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
May 01, 2007 | Canon PowerShot SD600 Digital Camera
Undo White Balance Sony F707
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Fuji FinePix F410 Digital Camera Logo
100 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
