Question about Nordic Track Nordictrack Asr 630 Elliptical Upper Harness 197780
NordicTrack ASR 630 Elliptical Console isn't working
I have the NordicTrack ASR 630 and the console isn't working correctly. It will turn on and light up when the batteries are in or the cord is plugged it, but it will not count the time, distance, or calories. It wil at times flicker and work for a few seconds, but then it stops and resets back to 0. The fan and resistance and workout features continue to work.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
NordicTrack ASR 630 Elliptical Console isn't w - 11_27_2012_11_26_14_pm.gif11_27_2012_11_26_37_pm.gif
Posted on Nov 27, 2012
ercupa190
  • 12223 Answers
SOURCE: i have a nordictrack audiostrider 800 that i just
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Posted on Nov 08, 2011
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
ercupa190
  • 12223 Answers
SOURCE: My NordicTrack A2050 no longer
Watch this video and Step:
http://www.youtube.com/watch?v=E-q-uS4t6so
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position
Chech: Optical Sensor if have it.
Posted on Nov 09, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
roadtech7
  • 293 Answers
SOURCE: nordicTrack c2255
Ok, your controller is faulty. Double check that your reed switch is connected and adjusted. It is located at the pully on the front roller. It is just outboard of the pully. It points at a magnet that is glued into the plastic pully. It should be about 1/8" away from the pully. If that is ok follow the wire back to the controller, it only has two small black wires, It has a red two place connector that pushes on the controller board. These are rarely the problem. If you are under warranty, get both the controller and the reed switch. If I would guess, It is the controller that is your problem.
Posted on Dec 01, 2011
Testimonial: "Matt, Thank you for the quick response and trouble shooting solution. I checked the reed switch and it appears to have the proper spacing. I will replace the controller. Thanks again. Telcomac"
Just looking for ways to trouble shoot this to figure out if/why it's not working.
If you wish to get some details; check the site linked here. Pull up older posts. Check for treadmill articles.
http://electro-medical.blogspot.com/
May 17, 2016 | Nordic Track Nordictrack ELite 1300...
Nordictrack elliptical asr 700
Hi There,
There may be a problem with a power wire inside the machine.
Ring Icon Fitness to repair.
Aug 24, 2014 | Exercise & Fitness
Display lights up but no information displayed
did you change the batteries or are you using a power cord?
Mar 25, 2014 | Nordic Track Nordictrack Ack Asr 630...
Nordictrack commercial 1300 elliptical
My machine will not start, any suggestions what I can do? i tried holding the start button, nothing. I checked the electricity works in the apartment. I tried the button combination and nothing. Any suggestions?
Nov 13, 2013 | Exercise & Fitness
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Elliptical pedal disk wont go back down
you must read the owner manual for relation with the terms.
if you do not have go to www.iconservice.com and download.
You must see the bolt for pedals, and see the magnet, adjust with the bolts, otherwise, that resistance will slip. secure it.
If the bolts are o.k test the magnet with the magnet from your refrigerator seal door. Test for attracted or repeled, replace if doesnot pass the test.
test the foot pedal , and see if the bolts are loose, tight with some wrench.Replace if they are breaking or damaged.
God bless you
Aug 29, 2012 | Nordic Track Nordictrack Audiostrider 630...
I have a nordictrack audiostrider 800 that i just replaced the console. now the resistance won't work. thoughts?
Oct 19, 2011 | Nordic Track NordicTrack Treadmill, A2550
It seems a belt has slipped off nordic track asr 700. How do I remove cover to get a better look?
You have to pull the upper console and console tower before removing the panels, If you have access to a owners manual I suggest looking at the explodes parts it will give an idea of disassembling the unit. If you need a manual the go to iconservice.com click on manual input this info NORDICTRACK ASR 700 ELLIPTICAL (NTEL00607)
May 21, 2010 | Exercise & Fitness
Nordic Track Nordictrack Asr 630 Elliptical Upper Harness 197780 Logo
1,557 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
