Question about Acer Aspire X3200 PC Desktop
Acer(w 1scr stopped working
Tryed all the thing on the web but nothing seems to do anything a few even said dont worry about it
  • 1 more comment
  • Paul Shute
    Paul Shute Nov 29, 2012
    still getting same message even after trying all you sugestedbut pc seems to working fine
  • Paul Shute
    cant seem to do a restore
  • Brian Sullivan
    Brian Sullivan Nov 29, 2012
    There was no mention of a message in your first post Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
  • Acer Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hope this helps.
Posted on Nov 27, 2012
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Acer aspire one- froze last night while browsing on the internet and turned off. is working ok now, but could this be a problem????? it is a ZG5. so far its been working ok, but i am concerned that this is...
Unless you actuallt get the blue screen of death, don't worry too much....you may have just had too much going on for the ram and processor to handle along with the web traffic in and out of the computer...sometimes causes things to slow down to a crawl and even freeze. Sometimes they work themselves out and sometimes they dont and you have to reset the system.
Sep 01, 2009 | Acer Aspire One PC Notebook
Desktop permantly frozen
it seems that your harddrive have problem.
try to bring your laptop to a service center and lt them reformat your unit.
i guess some file are corrupted with virus.
thanks,
Jun 23, 2009 | Acer Aspire 5720 6497 Laptop
Bought a Acer 9301 awsmi and its not switching
No, system will not stop working.
SATA and IDE drives have different connectors, so if motherboard is made to take SATA - it takes SATA, if IDE - then it takes IDE.
Also IDE drives are past. SATA drives are much better and works faster.
So there is nothing to worry about.
Mar 28, 2009 | Acer Computers & Internet
Acer Aspire 5050 won't boot at all
Yes, it's not the hard drive.
More than likely it's your motherboard.
There's not much you can do besides trying to boot the computer without the battery, and removing and reinstalling the memory.
Hopefully you'll get lucky!
Feb 28, 2009 | Acer Aspire 5050 Notebook
Acer One Screen Won't Come On--
Hey,
if this computer is still under warranty you can contact acer to get a replacement or repair for it.
If you are outside of warranty there are a few things we can try, one unplug the battery and ac adapter for 15 minutes, plug in the ac power and try starting up.
if that doesn't work, call acer and confirm your warranty. if you don't have warranty we can try other things. if you do have warranty and the repair is free, use it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | Acer Aspire One PC Notebook
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
I have an acer aspire one. my web cam is not working. it always says that the cpomputer cannot detect the webcam. how come it cant detect the cam if its a built in camera?i cant use it even in the YM...
i seems that your computer does not installed web came drivers. install it from the cd comes with the pc if you dont have one download from the acer web site.
Dec 20, 2008 | Computers & Internet
Network connection
It probably stops working due to the heat. The solder connection to the motherboard may not be up to par. To get round it I would purchase a PCI network card and use that instead. If the mouse bothers you, you can always unplug it, but it is something that you dont need to worry about.
Mar 22, 2008 | Computers & Internet
Acer Aspire X3200  PC Desktop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
