Question about Home Security
My Centurion D5 will intermittently reopen the gate immediately after I close it. The LED lights flash 4 times which I believe indicates an obtruction but there is no obstruction. Any thoughts as to w
The problem has been ongoing for a few months now but has become more frequent of late. I find that releasing the gear and then resetting the motor helps but not every time.
SOURCE: lift master 1265lm 1993
I have had the same problem.  The nylon gear that drives the chain started to strip, and was slipping. It finally wore out completely, and now needs replacement.
Posted on Dec 17, 2008
  • 188 Answers
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Posted on Jul 23, 2009
  • 366 Answers
SOURCE: my sl 3000 ul gate wont open unless I help it out
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Posted on Jan 24, 2010
  • 3197 Answers
SOURCE: Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Posted on Apr 26, 2010
SOURCE: Mighty mule gate opener motor burned up after 2 years
Did you ever find a motor to fix the gate opener? I am looking for the same motor and would appreciate any help you can offer
How to program a ET BLU MIX remote on a older type centurion d5 gate motor
Ask the shop what to do when their suggestion does not work.
Oct 02, 2014 | Televison & Video
Centurion d5 troubleshooting
Check the antenna at the gate for corrosion at the connector and make sure it's not bent. Water can get in and make the connection intermittent. Also tighten the screws on the main control board where wires from the receiver connect.
Aug 28, 2014 | Building Materials
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Hi there. The symptoms you describe as well as the error indication (4 flashes) certainly do seem to indicate an obstruction. Try disengaging the gate, moving it back and fourth and feeling whether it sticks at any particular point. Possible causes could be: dirt or stones on the rail, bad rack joints, missing teeth in the rack, worn wheels or guide-rollers or a damaged rail. You can also try decreasing the collision sensitivity (I can send you an email with the info if you like), but please be advised that this makes the gate less sensitive to an obstruction and could pose a risk. How old is the motor, if I may ask?
Nov 27, 2012 | Cars & Trucks
I need to know how to programe extra remote for my centurion D5 moto gate
If you Google Centurion D5 moto gate you will find a video listed that shows how to do what you need.
Jul 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have bought 2 new remotes for my centurion gate motor and the shop assistant told me how to program them.....except it doesn't work - please can someone give me step by step instructions on how to do...
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
Jan 13, 2011 | Televison & Video
Hi, I have a centurion d5 motor on my gate,but recently the gate only opens sometimes halfway or quarter way,othertimes it opens full. I checked the wheels and the tracks, there are no stones or any...
I have the same problem, i have replaced the bevel gears twice and that solved the problem for a short time. Take a look at the play on the bearing housing where the beve gear goes in. It most probably is worn.
Oct 19, 2010 | Clarity Televison & Video
I have bought an additional remote which I must programme with my centurion sliding gate motor. I need some assistance, but I don't want the other remotes to go out of sync. Please assist. Thanx Dawie
Steps to Programming Centurion Nova Remotes
1. Unlock the motor cover with your Centurion Key, remove this cover.
2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase.
3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins.
4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate.
5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button.
6. If further Remotes/Transmitters are to be added to the system, repeat step 5.
7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins.
8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Aug 28, 2010 | Televison & Video
Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
Sep 07, 2009 | Televison & Video
Home Security Logo
32 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
