Question about Panasonic TH-42PX60U Television
Cable connection broke off bake of unit
Got leg caught on cable broke connection off back of tv. how do i repair connection?
    Problem Solver:
  • 5 Answers
If i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Posted on Nov 27, 2012
Cable connection in TV broke off
That part is soldered into the TV circuitry. Chances are that a TV repair professional will need to open it up unless you know someone that knows how to desolate and solder in a new plug. If the circuit board is damaged, then you will have to source a new part.
Oct 20, 2014 | Seiki 32" LED TV - SE321FB
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
No volage at element posts.
your missing one 120volt leg,check your fuse/breaker panel then again at input terminals at unit and make sure you have a good neutral connection
Jun 19, 2009 | Ovens
Broken leg - need replacements
bake lite is very hard to repair
but i ahve made this very repair using a varied amount of things with varied success
depending on where it broke yo may want to try gorilla glue
if clost to the bottom get som jb weld from your harware store this will do it it may not be prtty but it will work
May 10, 2009 | Kitchen Appliances - Others
Cable connection broke off while unscrewing cable wire
The unit may be repairable depending the damage done to the input circuit that the connector was connected to. The board can probably be replaced if not repaired. You can call Polaroids customer support at this telephone number. 1-866-289-5168. Give them the model number of your television and the problem you had with the cable connector coming off inside the television.They should be able to tell you how your can get the unit repaired. I hope this information helps you with your problem.
May 04, 2009 | Polaroid FLM-3732 Television
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a Magic Chef range. My baking element in the oven caught fire and broke in half from the heat. I am trying to replace the element but am not sure if I am supposed to disconnect the element from the...
hi!!! All you have to do is go and buy a new heating bake element..turn off the power to the oven by the home breaker..then move the oven away from the wall and remove the back panel screws and look for the baking element it has 2 wires going into it.Very easy to fix..good luck..
Jan 03, 2009 | Kitchen Ranges
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Panasonic TH-42PX60U Television Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
