Question about OKI MICROLINE 520 Matrix Printer
Oki microline 520
Just purchased a back up printer for our system here at an auto auction. running a ibm as400. the printer is used and i have a flahing alarm light. i tried to reset to factory settings by turning off and on holding sel key and lf key and get nothing. i also sprayed it clean with a can of dust off. any suggestions
    Novelist:
    Champion:
  • 254 Answers
It is likely that a few different things can cause this condition. First suggest looking for the paper present sensor. This is usually an optical sensor with a lever which contacts the paper. If the lever is broken, or sensor defective, an error condition is exhibited, and printer won't operate. There is also a sensor for printhead home position, and perhaps one or more sensors at one end of the platen assembly. Some printers sense whether a lever is set for tractor feed style paper, or for standard single sheet. A NEC p6200 has one, and probably other printers too. Check for the presence and proper operation of these. You might have to remove a cover to see them... As you probably know, dot matrix printers are practically dinosaurs these days. You should be able to pick up a decent Epson or other good model for practically nothing, if diagnosis on your rig is fruitless. Companies began getting rid of these critters years ago.
Posted on Jun 06, 2007
  • Merwyn Bolles
    Merwyn Bolles Jun 07, 2007
    An additional thought: Some printers have a switch or other sensor which detect open covers, another place to look.
OKI MICROLINE 520 Matrix Printer driver
You can get any driver you want by installing : Driver Genius - the latest version .. and let it search through the internet :)
btw , here's a ( worked & safe ) link for D.G :
http://depositfiles.com/files/k7bzoizzb
Hope that link helps too :
http://www.driversimple.net/Camera-MP3-Player/Okidata-Oki-Ml-520-Elite
Good luck :)
Jan 10, 2013 | OKI MICROLINE 520 Matrix Printer
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
http://forums.windrivers.com/showthread.php?7080-RESOLVED-Okidata-Microline-184-Turbo
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
AND THERE IS THIS:
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Anthony
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
My oki microline 520 elite is showing alarm and the Character pitch of 15 is flashing
This is a checksum error. I would suggest replacing the main control board
Dec 09, 2010 | OKI MICROLINE 520 Matrix Printer
I have an alarm light onthe display, printer does not want to print?
I have an alarm light onthe display, printer does Problem with the OKI MICROLINE 520 Matrix Printer
Dec 08, 2010 | OKI MICROLINE 520 Matrix Printer
Lost installation disk for microline 520 printer
Did you check on-line with OKI? If they do not have it, check used computer stores on-lne and ask if they have it. Perhaps they can burn you a disk for a small fee.
Does you new computer have it in their database?
Go to Printer install, and check the OKI database in MS windows. Might be there. Just install and go to work.
Cheers.
Mar 27, 2009 | OKI MICROLINE 520 Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320
Use a IBM proprinter driver not Proronter 111 driver.
Hope this helps.
Dezzi
Apr 09, 2008 | OKI MICROLINE 520 Matrix Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
343 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
