Question about Bose Acoustic Wave (32022) 5-Disc CD Changer
Cds wont eject and the word charger flashing on the lcd
I have a 2002 Jeep Grand Cherokee Laredo and the cd player wont play or eject the cd. doesn't even register that one is in there
its bad, check fuses. if the fuses are good the head end player
needs service.
best is to upgrade to media center with USB and use only dirt cheap
FLASH memory for music, CDs are dying,
we rip;ours to mp3 and parked the CDs in the attic for eternity;.
Oct 01, 2014 | Jeep Grand Cherokee Cars & Trucks
Cd light is dark blue highlighted and the cds wont eject and wont play,how do i get it to eject?
There is a small hole in the front of the CD player that you can insert a paperclip into. That should force an eject.
Nov 18, 2010 | 2008 Cadillac Escalade
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
My cd player won't eject cds
you might try and look inside the CD slot with a flashlight and if you can see a CD try to remove it with tweezers,you do have power to the player right? if no power it wont eject,
Jan 11, 2009 | 2002 Ford Excursion
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
2001 Lincoln LS Can't get the CDs to eject
my problem is with the alpine system. it only ejects when cold. if tried when hot it jams and wont play cds or release until cold again. i removed the panel above the radio and place an icepac on the radio and after a while it starts spitting out cds
Jul 22, 2008 | Panasonic CQ-DPX33 CD Changer
Cd stuck in player not ejecting or accepting other cds
hi you nhave a faulty u8nit. there is a repair kit, but its not easy to fit, please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
Mark
Jun 07, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Stuck CDs
If you don't care about the disc player and want to get the cd's out you can easily take it apart yourself[make sure you unplug it]
Dec 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
