Question about Lincoln Welding Tools
Lincoln 275 220 volt 275 square wave welder just hums no lighs comes on and fan doesnt run no arc
4 Suggested Answers
GiantTechGuy
  • 25 Answers
SOURCE: GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Posted on Jan 19, 2009
co7196
  • 3433 Answers
SOURCE: have a lincoln square wave 175 tig maching with
buy a Cobra lead and torch head already equiped would be you best bet.
Posted on Nov 15, 2009
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
I have a Lincoln welder 255 square wave an I can't regulate the amperage
weld current output regulation on this machine is usually accomplished by voltage supplied across a 50 milli volt shunt that is usually connected at one end of the main rectifier, if this shunt fails, or if the connections are loose or damaged, you will not have current control, your control board may also have some issues
Upon removing the machine covers, if there is no easily seen damage, it will be best to seek out and take it to an LASF for repair.
Sep 01, 2015 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln square wave tig
The contactor has failed or a fuse is blown. You need to take this one to the local welding supply shop for service.
Aug 28, 2014 | Welding Tools
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
Have a lincoln square wave 175 tig maching with
Nov 13, 2009 | Welding Tools
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Square Wave Question
Square Wave refers to the shape of the voltage cycle in a welding arc. In an AC wave, a typical sinusoidal or sine wave, changes the voltage from positive to negative gradually, although many times a second. This means the voltage will not be consistent and at times will actually go through zero. Square Wave, on the other hand, changes the voltage from positive to negative almost instantly, making for a much smoother and more stable welding arc. This is particularly important when welding aluminum and when considering aspects like cleaning and penetrating action.
Aug 27, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
77 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
