Question about GE JVM1850 1000 Watts Microwave Oven
Does not heat food
I believe I need to replace the magnetron?
  • GE Master
  • 9,047 Answers
If the inside light, cooling fan, and turntable all come on when you press "Start" to cook, but it does not heat, then you have a defective high voltage section part (HV fuse, magnetron, etc.)
If the above 3 components do not all come on when you try to cook, then it\'s probably just a bad bottom door switch or mount.
My help file on door switches is here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel which is
very helpful when troubleshooting, testing, and locating
components.
Does not heat food - mini_manual_behind_grille_small.jpgdee77f7.jpgAt
we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This additional disassembly information may apply:
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they\'re removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
(There are three L-shaped clips that fit into a slot to hold bottom of the vent)
Then remove one screw (which holds the control panel in place) near the top of the control panel.
Once that screw is removed the panel tilts out so you can disconnect the wires and then slip it out.
Be sure to mark and/or photograph your wires so that each one gets back exactly where it was after the repair.
Reassembly is accomplished by sliding the L-shaped keepers in place, then sliding the vent grill to the right and pushing it into place.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven
here.
We\'re
happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Posted on Nov 28, 2012
SOURCE: JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Posted on Mar 29, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Everrything works - food does not heat up - two fuses OK
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
So verify that is working before you take the unit apart.
We have a sound clip of what a microwave should sound like when the cooling fan and all are working here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned , it's probably fine)
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
If you need further help, please write back with the results of your tests.
Posted on Jan 03, 2009
  • 17 Answers
SOURCE: Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Posted on Feb 08, 2009
  • 3 Answers
SOURCE: The guys here gave me good advice and that I
DO NOT!!!!!!!!!!!! undertake this job unless you have a pair of discharge leads and you know how to discharge this appliance the capacitor holds a charge large enough to kill you for about a month
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: kenmore model number 721.80593400 everything
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Jan 04, 2011
Want run or turn on to heat food
if your microwave is not heating food there could be two possible reasons. firstly maybe its the high voltage fuse that's gone,in that case the display is on the motor rotates but no heating since power is not reaching the magnetron. Secondly if your high voltage fuse is ok,display is there but no heating, the magnetron is faulty and it needs replacement
Nov 21, 2012 | Microwave Ovens
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Oven won't heat food
Bad Magnetron. Unfortunately, and especially on high power microwaves, magnetrons do die. They'll probably run you between 100 and 300 dollars to replace. If you believe that your microwave is within warranty(not likely), contact the manufacturer for repairs. Otherwise, it may just be cheaper to purchase a new microwave.
Sorry that this answer doesn't produce a happy result, but it's an unfortunate fault of microwaves as a whole.
Apr 23, 2010 | Maytag MMV5186A Microwave Oven
Food will not heat everything else is working
If it does not heat, with all other functions working, the problem lies with the magnetron circuit. The magnetron is the part that makes the microwaves to heat the food. Typically, the magnetron fails and shorts out. Symptoms when this occurs is a loud hum from the oven and does not heat the food. The replacement magnetron costs are close to the price of a new microwave oven, so it rarely pays to have it fixed.
Feb 16, 2010 | Goldstar Microwave Ovens
No heating
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | Kenmore Microwave Ovens
Does not heat up food
Benjamin
May 26, 2009 | Frigidaire FMV145K Microwave Oven
Microwave will not heat food and is noisy
Benjamin
Apr 28, 2009 | Microwave Ovens
Doesn't heat food or liquid.
Benjamin
Apr 25, 2009 | Kenmore 62622 Microwave Oven
Microwave doesn't heat food anymore
Benjamin
Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
It turns on ...lights up but doesnot heat or warm the food
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
519 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
