Question about Samsung Televison & Video
How to restart after signal failure
The picture froze no buttons worked so I switched off and left it for a few minutes and now the screen says NO SIGNAL. How do I restart ?
  • 26 Answers
Try this turn the TV off and hold the input button on the TV for A few minutes and it may come on. Then select the input you are using. If this doesn't work you probably have A bad main board.
Posted on Nov 27, 2012
SOURCE: 15PF9936/12 Flat TV
need new tv
Posted on Feb 20, 2008
  • 453 Answers
SOURCE: cable quit working says no signal
if u are using the cable input make sure u are un chanel 3 , other way to connect the cable box is thrught the video 1
Posted on Jan 17, 2009
  • 54 Answers
SOURCE: No Signal/VGA Input
use the " input " button on the remote control to select the input you are using to watch tv. she has accidently switched it to the computer input jack which is located on the side.
Posted on Jan 24, 2009
jan mczeal
  • 632 Answers
SOURCE: screen displays no signal after a power failure;
It's either the backlight lamp or backlight light inverter is busted due to the power failure.Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Posted on Sep 25, 2009
SOURCE: LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Posted on May 12, 2010
Turned off after froze in use, now it won't start up again
Plug the power cable and press the power on button.
Mar 07, 2010 | HP Pavilion dv6000z Notebook
I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
Oct 24, 2009 | Humax Televison & Video
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Please help my IPOD! It froze on the same screen w/ the light on
Slide the hold/lock switch on and off and then hold down the "Menu" button and the center button for about 5 seconds. If this doesnt restart your iPod, try the same procedure, but instead, hold down the "Menu" button and the "Play/Pause" button for 5 seconds. This should reset your iPod.
Hope it works!
Feb 23, 2009 | Apple iPod nano
Dell Inspiron 1501 Stuck on Start-Up
hey, this is not a problem of "windows" or something. it is a hardware failure most probably. Sorry to say that you can do nothing but tuurn it off (hold the power button till it turns off) and let it cool down for a few minutes then restart it. if it still doesn't work, contact DELL support...
Jan 10, 2009 | Dell Inspiron 1501 Notebook
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
My screen froze
hi i dont know if this solution would work .. but could you try to restart the ipod as in switch off and switch it back on...i mean power off and on..
The ipod i had , i had to press the play button and hold it for few second for it to power off.
Apr 18, 2008 | Computers & Internet
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
