Question about SonicWALL Content Filter List (01SSC2733)
How to switch over opt port to wan port in sonicwall
I have sonicwall t190. It heas two port one is WAN & another is OPT.
we have using the both port. give me a detail that when OPT port link is down then it is transfer automaticely on WAN Port.
  • 73 Answers
In order to do this, you will need to order the sonicwall OS enhanced. You can do this from your mysonicwall.com account.
After you upgrade the firmware, you will have a network load balancing option. you can then set the primary and secondary connections and use the active/passive failover option that is provided.
Posted on Feb 08, 2009
Running BGP on WS-C3750X-24T-S using IP Services IOS?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html
Apr 29, 2015 | Cisco Catalyst 3750X-24T-S Layer 3 Switch...
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Open Port Sonicwall
1. If the port is to be opened for internal people to access the port outside the network, add a firewall allow policy in Firewall -> Access Rules -> LAN->WAN
2. If the port is to be opened for external people to access the port in the network, add a firewall allow policy in Firewall -> Access Rules -> WAN->LAN
Jul 13, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
Anybody, please help! I need it! Sonicwall issues
There are many reasons for your problem, make sure you have the Computer and Register PC are in the switch section of the Sonicwall - not in the WAN port. The router should allow traffic to flow by default. Check the Operating system and turn off any firewalls, the router will take care of that.
May 03, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
I need to be able to ping the SonicWall TZ190 wan ip from the Internet for tracert puposes. There is no ping response to that IP address. The manual says. Click Objects, and then Services. Verify that...
Saibrains is correct unless your firmware is of earlier version. you might have to upgrade your firmware. Also you can not use a port #
No ports required for Ping as it uses icmp packets
It needs to allow icmp 'echo-request' (type 8) packets out and icmp 'echo-reply' (type 0) packets in
to allow ping request. On earlier versions of the sonicwall firmware it only absorbed Ping request as to stop hackers from ping attacking pass the firewall.
check the manufactures website for your model and see if they have newwer firmware.
The GUI should have a place where you can set it up
Apr 09, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
1,008 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Alun Cox
J John
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
