Question about Whirlpool Washing Machines
Hi, I'm an electrician and I have a problem with my washing machine! I have a 7kg front loader, model:- WFS1071BW. Originally i thought the door switch was faulty but it tests fine... the unit
Originally i thought the door switch was faulty but it tests fine... the unit drains for a few sec's then has a red light come up on the door lock indicator. Checking the pc board i found a regulator in line with the door switch had blown, i proceeded to replace the pc board only to find that the washer still has the same problem! Any ideas?? Thanks
    Sergeant:
  • 198 Answers
Just try to check the door latch device. Be sure that the latch is not bound or sticking in any way .This problem with a lot of machines and it almost always was the door lock latch assembly. It has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle. The door will actually be shut all the way and the lock may be on. You must replaced this switch so it works normal again..
Just click for the spare parts site link;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Nov 27, 2012
VOTIT
  • 2071 Answers
SOURCE: Washing machine door lock problem
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
  • 1294 Answers
SOURCE: Pulled the handle to early to open the 7kg front
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Try these sites for spares:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 02, 2009
  • 297 Answers
SOURCE: red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Posted on Apr 16, 2009
  • 3 Answers
SOURCE: My Whirlpool Duet Washer, model number WFW9400SW01 will not turn on. The button lock is off and does light up indicating power to the front panel/unit. Any ideas?
if you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
Posted on Jun 20, 2009
My lg front loader washing machine is getting stuck on the last 10 minutes of a cycle and has flashes of blue lights or sparks coming out from the underneath. What could be the problem with this?
blue lights and sparks indicate a serious electrical problem
call an electrician immediately and isolate the machine until it is fully inspected and pronounced safe
water , power and people do not mix
once you have determined the problem then get a quote to fix ir replace the unit
Aug 18, 2016 | LG F12C3QD White 600 mm Washer Front...
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
Whirlpool front loader washer model: WFS1071BW I have broken the knob/dial that controls all the functions. The one in the front, it looks like its snapped off from somewhere inside (the blue piece is...
Hello, Thank You for using FixYa. I will be helping you today.I believe you have to replace the whole user interface. Here is the diagram i dont see just the shaft. http://lookup.bellparts.com/diagramenlarge/whirlpool/4292/00061361
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi! My 7kg Samsung J843 Front Loader Washing Machine is not spinning at all. Makes a whirring sound but no movement. Any tips?
Hi, I've had this problem before. It was a while ago but it was either a broken belt or the belt had slipped from the correct position and needed to be put back on. It was under warranty and a service tech fixed it.
May 08, 2011 | Samsung WF337AA Front Load Washer
I need a manual for a Samsung 7kg Front loader washing washine model number J845
I googled the make and model of the washing machine and it bought up a site that had manuals that were in PDF form and I printed it from that.
In fact I got the manual for the washing machine, oven and microwave.
Nov 12, 2009 | Samsung Washing Machines
Front seal on whirlpool front loader (WFS1071AW)has torn and now leaks from front where can a replacement part be sourced
ck with whirlpool dealer or sears parts..sears.com has a parts look up system allowing part lookup for all national brands
Aug 09, 2008 | Whirlpool Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Westinghouse 798 front loader 7kg washing machine
God Sir
I am mr Yapi Antione from abidjan i am dealing with all washing marshing i saw your profle and i am intrested to to know the pris list of all the marshing in your company
i will like to haer from you as soon as posible
yours representetive
Mr Yapi Aantoine
you can reply me in this my email adress
yapiantione@yahoo.com
Or
Call me 0022501307526
Apr 04, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
361 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
