Question about HP Pavilion dv6000z Notebook
How can i check if memory is faulty on an hp pavilion laptop
When i start up laptop a hp pavilion dv6000z I get the black screen and I can't access the bios. I have tried turning it off, removing the battery, and adaptor, holding the buttton then restarting it using just the adaptor but to no avail. Ihave also tried reseating the memory and hard drive and still nothing. Can anyone help plz?
    Problem Solver:
  • 5 Answers
May be remove memory and give a good blow lots of dust gets in
Posted on Nov 27, 2012
  • 4 Answers
SOURCE: HP PAVILION DV9000 COMPUTER STARTS BOOTING UP AND THEN STOPS.
here is the only solution available on net:
give it a try:
http://amritbera.blogspot.com/2009/09/solved-hp-infinite-restarts.html
enjoy..
Posted on Sep 10, 2009
  • 159 Answers
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Posted on Oct 29, 2009
  • 120 Answers
SOURCE: black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Posted on Jan 09, 2010
  • 58 Answers
SOURCE: Hp Pavilion dvt 1000 black screen
As the notebook does not boot up and as you have already reseated the memory modules and tried connecting external monitor and as the issue is unresolved. It is clear that the issue is due to internal hardware malfunction of the system board of the notebook. However, before confirming the same, I would recommend you to perform hard reset which would discharge the static charges from the notebook. You can follow the steps listed below to perform hard reset:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will remove the discharge the static charges from the notebook. Now turn on the PC and check for the issue. If the issue persists, then it is clear that the issue due to internal hardware malfunction of the notebook and requires an onsite diagnosis. At this point, if your notebook is under factory warranty then I would recommend you to contact HP to get your notebook repaired under warranty.
Posted on May 27, 2010
MSG-CPC
  • 1325 Answers
SOURCE: HP Pavilion dv9000 Screen Black
hello
these links below have information (drivers, solutions) for your laptop, that will assist you.. review them , i am sure this will give you background causing BLACK display on your screen.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01997899&lc=en&dlc=en&cc=ca&product=3224049
http://h10025.www1.hp.com/ewfrf/wc/product?product=3224049&lc=en&cc=ca&dlc=en&lc=en&lang=en&cc=ca&submit=GO
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=27870&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=3224049
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01881110&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=3224049
Posted on Nov 08, 2010
HP Pavilion dv5000. Black screen. I can hear it load up & momentarily I can see even put in my password but the screen is faint then the black screen appears. Help me please
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 22, 2012 | HP Pavilion dv6000z Notebook
HP Pavilion DC6, Radeon Graphics card. How do I adjust contrast?
Start / Control Panel / Display / Settings / Advanced / Graphics Media Accelerator / Graphics Properties / Schemes
lots of clicks! This should get you what you want. You'll probably have to experiment with settings a little to get what is truly comfortable to you.
If this is helpful, please take a sec to rate me. Thanks!
Don
Mar 16, 2012 | HP Pavilion dv6000z Notebook
My HP DV6000 beeps 4 times and I end up with a black screen and the power button Flashing
Most likely a memory problem. If you have more than one stick of memory, remove one and try it.
If that doesn't work, remove the other one and replace the one you took out.
Nov 01, 2011 | HP Pavilion dv6000z Notebook
Screen wont turn on. try to start the laptop and it beeps three times one long then two short. then nothing just stays black.
Reseat your memory.Your memory fail during POST. Open the back compartment with 2 screws holding it and you should be able to get to the memory.
Usually reseating the memory will resolve if not replace them.
Dec 31, 2010 | HP Pavilion dv6000z Notebook
The laptop starts then black screen then restarts 25s later and it dosent stop.the hard drive maks a sound to.
The problem might be with the static charges on the motherboard, LCD screen, RAM or with the Hard Disk. Try the followings.
Remove Static Charges:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Still same, remove and reseat the RAM and Hard Disk. Check the below link for service manual.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer to page 128 of 278 (Memory Module)
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Refer to Page 123 of 278 (Hard Disk)
If still the same, you need to contact HP for hardware repair.
Sep 28, 2010 | HP Pavilion dv6000z Notebook
Hp omnibook xe4100 repeated beeps then black screen comes out. to start my laptop i press esc button before the beeps comes then esc again till i see mya windows
Try reseating the memory cards in the notebook to make sure they have a good connection.
if they lose connection you will get a black screen.
Jun 26, 2010 | HP Pavilion dv6000z Notebook
Hp Pavilion DV6000
hi, check the memory.. it might have problem..
regards
Mar 17, 2010 | HP Pavilion dv6000z Notebook
Memory upgrade HP Pavilion DV6304 Entertainment PC
yes it can be upgrade for 4GB for genuine HP memory. because hp exclusively use hp memory. all Hp pcs uses genuine hp memory.
Jun 07, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 Black Screen!
have you tried an external screen? did the same happen there
Mar 12, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
