I recently obtained a PAC S1000 split airconditioner. I is an older model, perhaps 2005/2006 I have no operating manual for this unit. However having looked at this model on the Internet, it looks slightly different than the model that I now have. Reason being is that my Unit does not seem to have the quick release/fastening joints. Question now is how do I get the Compressor unit outside and the Fan inside the room if I can not disconnect the lines? I would really appreciate some help here
  • pieterlip Jan 11, 2009
    Thank you very much.
    I was kind of expecting the worst, now I know
    Cheers
    Lip
  • 334 Answers
They will have to be cut and brazed.
Regular solder will not hold.
High temp brazing is required.
Also, it is illegal to cut into a refridgerant system without first recovering the refridgerant. It is also illegal to tap into refridgerant systems without having an EPA certification. It can result in very hefty fines.
I know thats probably not the answer you were hoping for. Howver, I would be neglecting my duties to not inform you of it.
Again, to directly answer your question.
If there are no disconnects on the refridgerant lines, they would have to be cut, and rebrazed.
This requires recoveery of refridgerant, vacume of the system, and an EPA certification.
Posted on Jan 10, 2009
2 Suggested Answers
SOURCE: Delonghi PAC S1000 Split Airconditioner
hello you will need to pump system down and disconnect flare nut or decant gas and then undo flare nutsthis is the only way to remove unit
I need an instruction manual for a Goldair Airconditioner (split unit)- any idea where I can download one?
Go to the manufacturer's website. They've usually have downloadable operator's manuals. ??
Jul 27, 2016 | Heating & Cooling
I am trying to find out where i can download a free manual for my fridgiaire airconditioner model# CRA087AT7....i have lost mine and need to obtain one can u help me out.
The model number you listed, may be incorrect (unless you have an older unit). All Frigidaire model numbers start with the letter 'F'.
Please advise, thanks.
Jul 04, 2011 | Frigidaire Heating & Cooling
I HAVE A DELONGHI PINGUINO ROOM A/C UNIT ITS AN OLDER MODEL PAC 75U WITH 7500BTUS I AM LOOKING FOR A MANUAL FOR UNIT.
http://www.appliancefactoryparts.com/airconditioners/delonghi/pac75u.html If you go to this web address you should find not only your parts but also the manual. I find this website helpful with most appliances.
Jun 10, 2011 | Heating & Cooling
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Lost Operation Manual
I was unable to locate your particular owners manual but click the link below and double check your model numbers. Also there is contact info so you can call to get more information if it is necessary.
http://www.fujitsugeneral.com/owners_manuals.htm
Mar 22, 2009 | Heating & Cooling
Jan 10, 2009 | Heating & Cooling
MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
Jan 24, 2008 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
