Boot block compatible version ver 0.16 bad bios
Boot block compatible version ver 0.16 bad bios check sum.bios recovery floppy not find. cd rom not find. i want a solution for this . iam using asus p5rd1-vm motherbord pls help me frnds
  • 57 Answers
Your bios i corrupt. You will need to download bios for your mother board, burn it on a cd and flash your motherboard bios. Go to your manufacturer site for more information on how to flash your bios using CD.
Posted on Nov 29, 2012
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Posted on Sep 14, 2007
  • 238 Answers
SOURCE: bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Posted on Jan 23, 2009
  • 10406 Answers
SOURCE: boot block compatible ver.024
Bad BIOS checksum: the software on a chip on the motherboard has become corrupted.
Sometimes, you can find a "BIOS update" on the manufacturer's web-site, so that the contents of that chip can be refreshed,
i.e., by booting from a diskette (or from a USB memory-stick) that contains the replacement software.
Contact a qualified technician, and pay them for 1 hour of labour.
Or, replace the motherboard.
Posted on Jul 17, 2009
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
How can i recover the bios
Flash Recovery-Config Some motherboard makers incorporate a flash recovery-config jumper or boot block recovery jumper on their motherboards. This can often be used to recover from a bad or failed flash. On most machines a small segment of the flash ROM does not get overwritten when you perform a normal flash update. This small portion of code contains a basic boot block which can enable the machine to reload another BIOS from floppy disk.
If you have a laptop or desktop without a floppy. You can either fit a floppy in the conventional manner or in some cases a USB floppy or CD-ROM can be used.
Aug 06, 2009 | HP Pavilion dv4000 Notebook
Boot block compatible ver.024 Please do not insert disc into cd-rom or floppy drive if you want to recovery with an usb device bad bios checksum.
Jul 17, 2009 | ASUS M2N-MX Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Bios failure
Sep 14, 2007 | ASUS A8V-VM Motherboard
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
