Installed MSI 7036 motherboard. Powered up, boot disk error, inserted XP CD, pressed Enter, no response, known keyboard plugged in , CTRL, Alt, Del not recognised. After a few minutes beeping starts. changed memory to known good memory, same problem. Could not connect plug for front panel Power on indicator, 3 pin plug, 0nly two pins available. Removed add-on plug in boards, still same problem. Board has been used before, not by me
  • 3,606 Answers
Hello a manual is always nice to have
Download here:
http://www.msi.com/product/mb/915GVM2-L.html#/?div=Manual
The file is in zip format so you have to unzip
it before you can read the content.
You also need adobe reader.
Other files can be selected in the download box.
Check the bios for basic boot up settings even load default settings.
Also check up all the wireing power, front panel etc.
Use a ps2 keyboard and mouse.
Check the cpu for propely installation
See also the power supply is working try it on another pc.
How many beeps come when you set the power on ???
Here is a list of beep codes:
http://www.5starsupport.com/info/beep_codes.htm
Good luck
Posted on Nov 27, 2012
SOURCE: MSI MS-6754 mother board won't boot and beeps when I swap processors
Ya know. I was trying a 533 FSB processor I see now that my motherboard only supports 400! Standby. Let me get a 400 and see if it cures my ills! Ahhhhh............
Posted on Sep 09, 2008
lolita
  • 385 Answers
SOURCE: Foxconn 6100K8MA-RS Motherboard
Hi You need to make sure that your boot sequence sets to boot from hard drive first. Also, make sure that the hard drive sequence has the hard drive enabled. If this does not work, then let me know so I can give another suggestion.
Posted on May 31, 2007
steve6375
  • 395 Answers
SOURCE: cmos checksum error - defaults loaded
Ports are usually labelled - look carefully.
Try manufacturers manual.
Could be that keyboard is the larger 5 pin DIN socket (old IBM AT keyboard).
Posted on Aug 10, 2008
  • 69 Answers
SOURCE: Good day, I inserted a
First of all does your power supply smell of burning?.... if so than you need a new power supply, otherwise you may have blown you motherboard which may include your cpu.
Please let me know what you find and I may be able to help you.
Regards,
Philip
Posted on Dec 07, 2008
  • 10 Answers
SOURCE: front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Posted on Jul 29, 2009
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
CD Drive will not allow boot
Change the boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 03, 2013 | Computers & Internet
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
It say's to my computer..."insert
make sure there is disk in your drives cd/dvd floppy
the operating system might not be detecting your hard drive
check all leads that attach from motherboard to hard drive include elctrical and electrical extensions make sure they have secure connections and power is getting to your drives hard drive cd/dvd and floppy
check the keyboard leads make sure the connection is secure also
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
hope this helps
Aug 12, 2011 | Computers & Internet
Please help!! my dell latitude d620 fails to boot displaying: YVFXP is compressed press Ctrl+Alt+Del to restart. When i do this it jus does the same thing.
Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved byfollowing these steps: 1. Insert the Windows XP CD drive onthe computer and restart the computer. 2. Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup. 3. When you get to the install windowsXP screen: 4. Press Rto repair the Windows XP installation using Recovery Console. 5. Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS . 6. If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter . 7. At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type: cdc:\ Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cdd:\ 8. At the prompt, type: attrib-c ntldr and thenpress Enter . 9. At the prompt, type: exit 10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
Mar 05, 2011 | Dell Latitude D620 Notebook
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Soyo sy-p4vgm motherboard unable to access BIOS setup menu
Offcourse! first of all insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
2nd way, If everything could not be possible then you should boot from CD again then select your CD drive and type a command fdisk and press y or enter 2 times. Now you choose 4 number and press enter and check the drive format if it is not FAT32 its mean that you should press 3 and then press 4 and now press enter then press escape. Then press three button at a time Ctrl+Alt+Del now your system will reboot now once again Boot from CD and choose CD drive and type fdisk and choose 1 then choose1 and now press enter and once again press three button at a time Ctrl+Alt+Del now your system will reboot. Once again boot from CD and select your CD drive and now you can install windows 98 now insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
Thank You
Jul 30, 2009 | Soyo SY-P4VGM Motherboard
COMPUTER START UP ONLY WHEN WE INSERT THE WINDOW XP
have you installed the operating system yet? If you have you need to go to your bios and change the load set up from the cd to your hard drive. On start up press F8 and change boot up to HDD.
Jun 08, 2009 | Compaq Deskpro EN FC 6450+ Model 10000...
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
