Ferguson TV DVD fault - won't play discs
Reads discs then ejects so unable to play
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Check its loading mechanism for proper disc loading. Replace the loading belt first and check. If it does not help you, insert a cleaning disc into it. If the fault is with accumulated dust or dirt on the laser pick up lens, it will be cleared out. If not, replace the laser pickup unit.
Posted on Nov 27, 2012
  • Howard John Parker Nov 29, 2012
    Inserted cleaning disc but afraid it didn't cure the problem. Looks like the built in DVD player is bust. Plan B is that I have a stand-alone DVD player which I can hook up instead.
  • 11800 Answers
SOURCE: Sony bravia DVD disk won't
Mechanical failure of the tray's mechanism - the clicking you hear is made by the wheel on the motor of the tray skipping over its eject lever.
The mechanism will have to be extracted from the tv as a whole then dismantled to see if the wheel can be reattached to the lever. If that is impossible (both plastic parts have been damaged) then the entire mechanism is dead and it will have to be replaced.
Since this is a brand new model and you bought it a few months ago it means that it's still in the warranty period. Because of that the entire repair/ replacement of the BR unit will be done for free by the dealer. Under no circumstance you should attempt to fix it yourself - opening the tv or forcing the unit will void the warranty.
Posted on Sep 15, 2011
SOURCE: my dvd disc won't go into the slot on my westinghouse tv even tho tv has been turned on
Are you sure you are installing it correctly? Try both sides and then see if it is accepted. If not, then the drive is bad
Posted on Oct 24, 2011
javswr
  • 44 Answers
SOURCE: DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Posted on Feb 28, 2009
SOURCE: READS WRONG DISC
Whenever we insert a DVD is says wrong disk
Posted on May 29, 2008
SOURCE: I have an LCD/ DVD
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Posted on Aug 07, 2011
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
Tv won't read disc that have been played in it before
If you get a cannot read disc etc either you have a dirty or a bad optical pickup unit in the player--it reads the disc etc.
If bad cheaper to buy a new unit.
Jun 14, 2012 | Disney DTD1363-CAR 13" TV/DVD
Reads dvd cleaner but incorret disc when plays movies
Check with an other disc. If the video format doesn't match this type of fault can occur.
Apr 29, 2012 | Orion TVDVD092 9 in. TV/DVD Combo
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
Drive Reads & writes CDs but only reads DVDs. Attempts to write a DVD ejects the disc with a 'insert writable media' prompt. Device manager says driver 'up to date'. Am I using the...
my desktop computer will not write to a dvd, but will play a dvd
& my laptop will play a cd but will only write to a dvd
it's just the way the drives are,,I've tried different types of dvd also nothing helped
Sep 07, 2011 | Computers & Internet
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
Aug 07, 2011 | Televison & Video
None of my dvd's will play. The dvd player reads no disc and the message on the tv reads unable to play disc.
try cleaning the IRIS in the dvd player with a cleaning disk Quite often it is just dirt on the laser iris.
Sep 23, 2009 | Televison & Video
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
