Question about Sony VPH-1001Q TV
How do i invert my picture on my vph 1001qm
Im sitting my unit on the table but the previous owner had it mounted on the ceiling so picture is inverted. how do i get it inverted back to normal thks nigel
    Scholar:
  • 67 Answers
Heya,
I just found this
www.curtpalme.com/docs/Sony1001_1044_Install.pdf
Page fifteen gives you instrustions how to change it. If you can veiw it let me know.
But I just read it
Posted on Jan 10, 2009
  • anthonyrepol Mar 12, 2012
    Do you have a picther of how to do it
Our picture is upsideddown how do you rotate the picture???
Go to the Option menu and select Installation then if your projector is sitting on a table or shelf, select "front/desk". If your projector is installed on the ceiling, select "front/ceiling".
That should solve the problem.
Aug 22, 2011 | Panasonic PT-AX200U Projector
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
The images are upside down how do i change, i read somewhere that change the front ceiling on the menu how do i do that?
Your projector is in "ceiling mount" mode. I don't know all of the menus for your specific model, but if you navigate through the menus you will likely see an option for ceiling or table mount. This may be a picture rather than words. Also in the same menu list should be front or rear projection. A change to this will flip the picture to the correct orientation.
Dan
Apr 11, 2011 | Epson PowerLite 62c Multimedia Projector
Connected the projector to laptop but projected image is inverted
These projectors are designed to either sit on a table, or be hung from a ceiling bracket. Depending on how it is used, the image may be upside-down, like what you are experiencing.
Most projectors have a function to invert the image. Check your manual, and see if the setup menu offers image invert, or something similar. Once you get it solved, you'll never have to fool with it again.
Jan 25, 2011 | Mitsubishi DIGITAL ELECTRONICS XD250U DLP...
Are there any error codes listed anywhere for fujitsu ductless split units im an electrical contractor. we rewired a brownstone in 2008. trying to help the owners out, i installed a 3 ton ceiling...
you did not give a model number but, try this link and see if you pull up the owners manual. it should have codes.
http://www.fujitsugeneral.com/owners_manuals.htm
Dec 21, 2010 | Heating & Cooling
How to invert picture when mounting on ceiling
go into your menu and check the box for ceiling mount or something like that.
May 20, 2010 | Office Equipment & Supplies
MY VIDEO PROJECTOR SONY VPL -HS10, CONNECTED TO COMPONENT VIDEO OUTPUTS IS DIPLAYING DATA ON THE SCREEN UPSIDE DOWN. HOW DO I CHANGE THIS PLEASE
There should be a menu option for orientation. The selection may be for ceiling vs standard. You have the unit set for ceiling mount.
Dan
Sep 12, 2009 | Sony VPH-G70Q Video Projector (VPH G70Q,...
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
Canon lv-7220 inverted view.
Yes,
Go to the menu and setup the prj mode.and the image will be inverted.
Viren
Nov 16, 2007 | Canon LV-LP18 Projector Lamp for - LV7220,...
Televison & Video Logo
132 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
