Question about GE GSS20IEM Side by Side Refrigerator
How many cubic feet is the ge gss201EMD
I need to know how many cubic feet this refrigerator has
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I have a GE Refrigerator model # TEX21J1SRRAD 20.6
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
aasc
  • 1606 Answers
SOURCE: what is the cubic feet of gts18fcsarww
18 cu ft . Look familiar ?
Posted on Oct 10, 2009
  • 1891 Answers
SOURCE: GE Profile Artica 22.6 cubic feet side by side
may need a main board or sensors that control the board . or both . ,, mm
Posted on Aug 11, 2010
BElectric
  • 1140 Answers
SOURCE: I have a GE Profile
Hi -
The TFH22 has a nominal size of 22 cubic feet total capacity - 21.7 cubic feet if you need to be exact. The fridge:freezer size split is 60:40, but the ice-maker reduces the capacity of the freezer, so the capacity is split as follows:
Fridge capacity: 14.5 cubic feet
Freezer capacity: 7.2 cubic feet.
These figures are correct to within +/-0.2 cubic feet for each. If you need to be more exact, you need to call GE as they no longer publish these specifications. The manual covers the 22, 24 and 27 cubic feet models, so the individual specifications for each one are not included.
Hope this helps. If you need further assistance, you can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 30, 2011
Model# FRT17B3JW6. need to know cubic ft. for selling
Normally the first two numbers in the model number are the cubic feet. You have posted 2 model numbers, on appears to be 21 cubic feet and the other is 17 cubic feet.
Jan 21, 2013 | Magic Chef CTF2125 Top Freezer...
How to repair a GE Profile Arctica 25.4 Cubic Feet Side-By-Side
This might help you...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Sep 29, 2011 | GE Profile Arctica 25.4 Cubic Feet...
How many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
Sep 08, 2011 | GE Refrigerators
RE: GE GTS16BBMFRWW What is the cubic feet?
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Sep 08, 2010 | GE Refrigerators
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
GE GSS20IEM Side by Side Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
