Question about Samsung Digimax L60 Digital Camera
Samsung l60 igimax wont let me scroll and see all my pictures.turns off
I keep getting to the same point when looking at my pictures then a green light flashes near the lcd display and turns off!! Have checked battery whichis fully charged etc. This has happened countless times and now I dont know what to do. Never had any problems with this product before hence am disappointed. Please help me!
    Genius:
  • Samsung Master
  • 1,019 Answers
The camera has an internal circuit problem that requires repairs.
Posted on Jan 26, 2013
SOURCE: Camera won't turn on
not sure if you have the same problem..but i have the same camera and when i turned it on the screen was all white..it still worked and took pictures but i could only see them on the computer.. i had my friends dad open it up and he found a foam like piece that fell from somewhere and was causing a wire to short out in the LCD screen.
Posted on Mar 23, 2007
SOURCE: Camera Wont Turn on
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Posted on Oct 30, 2007
prerit_777
  • 214 Answers
SOURCE: I cannot charge my Samsung L210 digital camera
it has a technical problem you should go to a person who repairs
Posted on Aug 23, 2009
lock123
  • 6831 Answers
SOURCE: Samsung PL150 shut down after starting up, lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
SOURCE: my samsung pl100 wont turn
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Posted on Dec 30, 2010
Digimax l60 says card locked
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 19, 2012 | Samsung Digimax L60 Digital Camera
The exposure is too high
First reset your camera setup to factory default settings, then try it. If that doesn't fix it let me know.
May 20, 2010 | Samsung Digimax L60 Digital Camera
Pictures over exposed
Try setting the ISO to a lower number. If you can't find "reset" in the camera menu, you can do a manual reset. Here's how...remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Apr 04, 2010 | Samsung Digimax L60 Digital Camera
Overexposure on Samsung Digimax L60
Had same problem after 2 years. Took it in to a repair shop & they installed a new camera flex. Its working OK now.
Jul 21, 2009 | Samsung Digimax L60 Digital Camera
Smashed LCD screen on Digimax L60
You can try Samsung to get it fixed but usually it is cheaper to get a new camers.
Feb 04, 2008 | Samsung Digimax L60 Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
Digimax L60 issue
When I turn my l60 on, the lens doesn't open all the way. Usually I just use my finger to help it along... then earlier tonight I turned on the camera again to take pictures and all I had was a white screen. I took out the battery.. then the sd card, nothing worked.
I later came online and searched for solutions.. seems this is a common problem for other cameras as well.. I tried their methods.. they say to hold the camera and just tap on it.. I tapped on the Samsung logo a few times.. the white screen was still there.. and I gave up, turned the camera back off... then decided to try again, turned it on and now I have my lcd screen working again. O_o *shrugs* I'm not going to question how it got fixed, I just hope I don't get this problem again.
Nov 18, 2007 | Samsung Digimax L60 Digital Camera
Digimax L60 will not recognize my card
Your Digimax L60 will also recognize your SD card please select the option to save pics
In camera or in memory card. This time your camera work on its internal memory.
Oct 11, 2007 | Samsung Digimax L60 Digital Camera
Samsung Digimax L60 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
