Question about Acer Aspire 3623WXCi Notebook
Where i can buy the lcd front bezel parts of acer aspire 3623 wxci?
  • 564 Answers
You could try ebay
Posted on Nov 27, 2012
3 Suggested Answers
  • 177 Answers
SOURCE: DVD DRIVE DRIVER FOR ACER ASPIRE 3623
Generally you don't need the Optical drive driver. Windows XP has built in drivers to support them. If you tell the exact problem then may be we can help
Posted on Nov 25, 2008
a_linder
  • 53 Answers
SOURCE: I am looking for drivers
You should find all you need here:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=114
Hope this helps ;)
Posted on Jan 28, 2011
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
How do i disconnect the touch oad from my Acer aspire 5541
FN & F7 turns off the touch pad. Want it back on? Do the same.
Jan 13, 2013 | Acer Aspire 5241 5332 5517 5532 5541 5732z...
I haVe a Acer aspire one with a black screen on startup
first I would try the screen cable you have to open the front of the screen take of the bezel check behind the screen happened to my last week
Dec 28, 2012 | Acer ASPIRE ONE ZG5 COMPATIBLE LAPTOP LCD...
Can you tell me does the acer aspire 57322 have a built in microphone
Most of these Aspires have microphones built into the LCD bezel. Look for a tiny pinhole at the top of the LCD bezel. There may even be a small picture of a microphone etches into the plastic at that area.
Jun 07, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Hi! im looking for parts for a acer aspire 5335-2238 like the two half's(bottom & top)and the back bezel of the LCD.
I would suggest looking on Ebay.
1.Computers and Networking>PC Components>For Laptops and Notebooks>Acer Aspire 5300 series
[For the LCD bezel. That's the frame that goes around the LCD screen, in the front. The cover on the back of the LCD screen, is the Top Cover. The cover where the keypad is at, and the touchpad, is the Palm Rest]
2.Computers and Networking>PC Components>For Laptops and Notebooks>Laptops and Notebooks For Repair>Acer
Perhaps see if you can find a laptop for parts, that may have all the items you listed.
Sep 04, 2009 | Computers & Internet
Anyone replace the inverter on an Acer Aspire 6920?
I haven't replaced an inverter on this model before, but have done on a few other makes.
Generally the inverter is located on the bottom edge of the LCD screen behind the bezel.
The bezel is secured with screws on the front and or the edges of the bezel. these screws in most cases are hidden by small round plastic covers, they need to be carefully peeled off to reveal the screws. Also the bezel is held in place with plastic clips and double sided tape. Slip a thin metal strip between the screen and the bezel and carefully pop the bezel off, start at the bottom edge and work along each edge to release the bezel. Be careful not to scratch the LCD screen and be careful not to apply pressure to the face of the LCD screen otherwise you will crack the LCD screen.
Aug 12, 2009 | Acer Aspire 5720-6661 Notebook PC
Back light on my acer laptop is not working been told its the inverter I have the same problem with my Acer Aspire 5610-4491. The backlight lamp sometimes goes out for loooong periods of time and...
I assume you can see a faint image on the panel but it's just not lit at all.
you cannot replace the lamp, as it is part of the lcd itself. If the laptop is in warranty, contact acer. if not, try this:
remove the lcd bezel (front plastic). peel off the sticky dots and undo the screws to remove the bezel. The inverter board will be at the bottom of the lcd panel - basically right behind the acer logo on the bezel. disconnect and reconnect the connectors on each side of the inverter board - it might just be a bad/loose connection. If this doesn't fix it, it's probably worth gambling on a new inverter board. Call acer, it's a very inexpensive part ($20 probably)
Hope this helps!
Jan 18, 2009 | Acer Aspire 5610-4491 Notebook
Nov 25, 2008 | Acer Aspire 3623WXMi Notebook
Acer Aspire 3623WXCi Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
