Question about JVC DR-MX1 DVD Recorder/VCR
Reset JVC DR-MX1S - JVC DR-MX1 DVD Recorder/VCR
3 Suggested Answers
SOURCE: JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Posted on Feb 20, 2008
  • 72 Answers
SOURCE: Hi I am trying to
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Posted on Jan 14, 2011
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
Does nothing when plugged in says it is loading and it doesn't
hello,
since your dvd keeps saying itis loading and it is not.
that simply means the lens of the dvd is already weak.
try cleaning it with a lens cleaner,
or better still you can replace the lens.
take care
May 27, 2010 | JVC DR-MX1S DVD Recorder/VCR
JVC DR-MX1 loading error - how can I retrieve hard disk hdd conte
well, i sympathize with your problem- it may be a bit expensive, but there are 'data recovery' services available on-line. if the data on the hd is still intact, then they can either 'burn' it to dvds, or transfer it to an external, usb hd. then, if your pc has a dvd burner, you can archive the content to dvds! store them in hard case holders-make copies and store them in a safe place! fire-resistant safe, safe deposit box, with a trusted relative or friend, in case the originals become damaged. also, use the external to archive any future pictures, or videos- then back them up on dvds! would suggest 500GB-1TB usb 2.0 external,if your pc can support it! $85-150. cheap!
might send the external along with the 180MB to whatever service you decide to go with, that will save some $$, in the long run. (or it should- research what the recovery services offer!).
good luck!
Oct 04, 2009 | JVC DR-MX1S DVD Recorder/VCR
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
I plug it in to mains and all that happens is a white light comes on on front panel it also flickers every now and again?
You almost certainly have problems with the power supply board which fails fairly often in these machines. They are available for around 80 euros, trouble is that having bought one it is not uncommon to plug it in only to find you have another problem. Your best bet is to take it to a big JVC service centre where they will have the spares to try substitute components without you having to buy them first!
May 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
I recorded a dvd and it will not play in any other player.
You must finalize the DVD after recording it. If you post the model of the JVC device, I may be able to find out how to do this for you.
Jan 12, 2009 | JVC DR-MX1S DVD Recorder/VCR
JVC DR-MX1S
JVC DR-MV1S DVD Recorder / VCR... Problem
if you can actually reset the dvd/vcr recorder try the dvd menu...it should be under one of it's submenus
Jan 18, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MX1 DVD Recorder/VCR Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
