Question about Mitsubishi Outlander 08 2008
Mitisubishi outlander no cranck signals
Don't know how to install crack sensor pickup
    Sergeant:
  • 344 Answers
Install it thats how,DAAA
Posted on Nov 28, 2012
Show or explain how to replace cam sensor in 2003 mitsubishi outlander please?
How do you know the sensor needs replacing?
Was it looked at with a scan tool & component tested
& found to be bad?
Codes have nothing to do with replacing parts
They are used to diagnose the reason they are set
The internet has pictures of parts locations
That is a job for the the best of shops, to diagnose,
& actually find a problem
Jul 02, 2014 | 2003 Mitsubishi Outlander
85 Toyota Pick Up 22R (carb) not getting spark
Sounds like a crank sensor to me. I believe this will be found just below your bottom pulley [ crank pulley] . This is responsible for getting power to the coil. These are sometimes hard to get out . I just broke it off and used a socket. I don\'t know how you can test this sensor unless you have a wire test kit. I am not positive on this, but I\'m pretty sure. It sure sounds like it. Let me know how you make out.
Jan 12, 2013 | 1985 Toyota Pickup
Power Loss in my 1994 Nissan 4 cyl. pickup
You obviously don't have the knowledge to diagnose
those problems & don't appear to be doing any testing,
so stop throwing parts at it & go to a repair shop
Jun 17, 2012 | 1994 Nissan Pickup
Where does the map sensor sit
Hi, see the picture below. Before replacing the MAP sensor, check the vacuum line for leaks. If the vacuum is good and you have a voltmeter, check the signals. With the key on, there should be 5 volts DC between the outer terminals of the connector. Don't take it off--just stick your meter probes in the back of the connector until they touch the bare wires. If you don't have 5 volts there, the problem is not the sensor--it's the wiring or the computer. If you do have 5 volts there, check the voltage from the white wire to either of the other 2. That voltage should be between 1 and 5 volts, and it should change a lot when you start the engine. If it doesn't change at least a couple of volts, the sensor is probably bad. Please let me know if you have questions, and thanks for using FixYa.
Sep 03, 2011 | 2006 Chevrolet Aveo
Code p0131 Excessive fuel consumption Intermittent no start (cranks, fires up then dies) Replaced Plugs and wires Fuel filter 02 sensor I don't know where to go from here
CODE PO131 - HO2S 11 BANK 1 SENSOR SENSOR I CIRCUIT LOW INPUT CONDITIONS. POSSIBLE CAUSES LOOK FOR INTAKE LEAKS IN THE EXHAUST SYSTEM, LOOK FOR INTAKE VACUUM LINES LEAKS. FUEL SYSTEM TOO LEAN WEAK FUEL PRESSURE CLOGGED FUEL FILTER,WEAK FUEL PUMP. FAULTY HO2S SENSOR.OR HO2S SENSOR SIGNAL CIRCUIT SHORTED TO SENSOR. HO2S SENSOR DAMAGED CRACKED OR HOLE CLOGGED. PCM HAS FAILED.
Aug 12, 2011 | Chevrolet Malibu Cars & Trucks
Cant find sparkplugs on mitsubshi outlander 2006 4cyl.
Not familar with your engine, but we get a lot of
those questions everyday
The answer is: you either never looked very hard
or have no idea that half of all vehicles today are hemi
head engines & the spark plugs are under the
individual coils,you have to remove first, to get to
the spark plugs.
Not a car person since you were a teen,then I
understand,you haven't keep up with technology
When I see problem with 2006 Mitsu I have no idea
how that got there
This is an open social web site or forum,at home, don't
get paid,don't know anymore than you do, about this site
So what problems if any are you having?
Changing spark plugs won't fix much
They get changed every 3 years or 60,000 miles in the motor
I would guess you have 100,000 miles by now, so the front
O2 Sensors should be changed also
Aug 04, 2011 | 2006 Mitsubishi Outlander
Cam & crank sensor code intermitten spark 2.4
are they the same engines? and i mean exactly the same? if the arent the same maybe check and look at the starter ring gear and count the teeth...also check the camshaft sprocket...is it different?
Oct 09, 2009 | Pontiac Sunfire Cars & Trucks
Mitsubishi Outlander 08 2008 Logo
49 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Mister Danger
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
