Question about Corel Paint Shop Pro Photo X2
PSP photoX2 not responding
Hi , I've loaded the software , when i open it .. it freezes when 'updating cache settings ?/
  • Anonymous Jan 22, 2009
    The first time I loaded it, perfect. After a year I had a lockup problem so I reloaded it and found the updating problem. Even a full delete and reload doesn't help.
  • Anonymous Feb 09, 2009
    I'm having the same problem as a number of users. PSP X@ worked fine for awhile then freezes white "updating cache." No amount of system restores or uninstall/reinstall has solved this problem. This is unacceptable in today's market place and economy
The solurion to your problem is simple, go to Administrative Tools -> Services and stop ProtexisLicensing
(or just press Start-> Run -> services.msc and press Enter)
Stop the service and put on Disable.
Go to Strat-> Run -> sc delete ProtexisLicensing
and press Enter, now ProtexisLicensing will be removed from services list
Go to SYSTEM32 folder and rename these files:
- PSIService.exe - PSIService.bak
- PSIKey.dll - PSIKey.bak
Reboot your compter and reload the software. Should stop that not responding error. Paintshop Pro when it installs onto your computer also installs this adware onto the computer as well, in most cases by disable this service, it should correct your problems. Also a good idea is to disable that file indexer as well.. All that does is slow down your computer and you'll probably not use it in Paintshop Pro. It's not really needed. Hope this helps...
Posted on May 25, 2009
Itune 306 error
From http://support.apple.com/kb/TS3297
iTunes Store loads partially or returns "Error 306" or "Error 10054"
Proxies, parental control settings and software, security or filtering software, or a bad iTunes Store cache can cause this.
To address proxies, Remove Internet Options proxy settings and connect to the Internet without a proxy.
To reset iTunes Store cache:
  1. In iTunes, choose iTunes > Preferences (Mac) or Edit > Preferences (PC).
  2. Click the Advanced tab.
  3. Click the "Reset cache" button.
  4. Click OK and see if the issue is resolved.
Adjust Parental Controls in iTunes:
  1. Open iTunes.
  2. Access iTunes preferences:
    1. On a Mac: From the iTunes menu, choose Preferences.
    2. On a Windows PC: From the Edit menu, choose Preferences.
  3. Click the Parental Controls tab.
  4. Remove restrictions on Parental Controls.
Oct 22, 2013 | Apple iTunes
Why does my adobe flash keep freezing?
Update Adobe flash player and install adobe flash plug-in. If problem still occurs then remove unwanted tool-bars and disable unwanted plug-ins. Also clear Cache - for an instant fix i would suggest to use PC optimization tool like PCFresher.
Feb 17, 2013 | Adobe Photoshop CS3 10
Installation of Paint Shop Pro PhotoX2; Status bar: Starting Service, 10 sec remaining presents "error 1920: Service ProtexisLicensing failed to start. Verify that you have sufficient privileges to start...
The error you seem to get refers to the registration part of the install (obviously) ... this is usually not a problem and the fact that it has popped up speaks ill of the program. I am assuming you are indeed an administrator on this computer and as such you have the 'right' to install programs?
Nov 11, 2009 | Corel PAINTSHOP PRO PHOTO X2
Paint shop pro tools in psp 9 and 8 question
How much memory do you have on board?? Paint Shop, Photoshop all have high memory requirements to function properly. Freezing up is usually a sign of not enough memory. I would say 2 gigs memory should be about the minimum now. 3-4 would be better.
Oct 13, 2009 | Computers & Internet
Whenever I go to use the eraser too, psp freezes up for about 20 min or 1/2 hr. Says its looking for new items. What can I do about this. I hate to have to reinstall and lose all my settings. This is...
Erasing programs sometimes use a lot of ressources on the computer, so if you erase the erased stuff maybe you should wait until the eraser is finish to erase and the open PSP.
Hope thats helps
Aug 24, 2009 | Corel Paint Shop Pro® X Full Version...
My psp freezes on *updating cache setting*
I found this fix that worked for me:
A. Close Paint Shop Pro Photo XI if is currently open.
B. Go to Start | Run, Type %appdata% and click Ok. (Or find the folder under user\appdata)
C. Open the Corel folder.
D. Delete the following files:
ImageDB.db
LastDBFilter.PspCache
LastDBTreeSel.PspCache
thumbnails.db
E. Select the Paint Shop Pro Photo folder.
F. Select the 11 folder.
G. Delete the cache folder.
H. Close the open box.
Aug 18, 2009 | Corel Paint Shop Pro Photo X2
Does not open with vista
find the pageplus.exe in the installation folder, c:\program files\serif\pageplus\program
right click it and the select the compatibility tab, click change sttings for all users, tick the box "run as administrator"
May 11, 2009 | Serif PagePlus 8 PDF edition for PC
Corel Paint Shop Pro (any version) crashes while loading
i recently faced problem in paint shop pro x2...PSP was just freezes or stuck at load...i reinstalled it...It loaded successfully this time but soon became freezes when i shut it off and tried to run again....Now wht i did is this......
PSP Plugins was some whr incompatible or something other problem with Adobe CS4 Plugins..coz i redirected PSP to get load not just its own Plugins but also load Adobe CS4 Plugins as well....and thats whr my Problem started......
So wht i did is...just Cut the Plugins of Adobe CS4 to Desktop(for temporary purpose) and Load PSP again ...and it ran all fine...:)now i went to File/Preference/Locate File and remove the Path towards the Adobe CS4 plugins.....and then same Cut and paste Plugins(which i put on desktop) back to Adobe CS4 Folder......Now no problem at all....chao...
Apr 23, 2009 | Corel Paint Shop Pro 9
Sony Vegas 8.0 Freezes when "Initializing Audio Engine"
Have you upgraded you Sound Drivers? Tried reinstalling Vegas? or Looked to see if a Patch or Update is available for Vegas?
Apr 04, 2009 | Sony Vegas Movie Studio Platinum 8
Cant load micromeadia flash player for psp
Did you try installing the flash player from adobe? It may also be that sony psp will only recognize adobe flash player 6 http://www.brothersoft.com/adobe-flash-player-60081.html
Oct 25, 2008 | Macromedia Computers & Internet
Corel Paint Shop Pro Photo X2 Logo
653 people viewed this question
Top Corel Computers & Internet Experts
Barbat Nae
Barbat Nae
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
