Question about Hilti 285359 SF 121-A 2.0 NICD Cordless Drill/Driver
My hilti 7/36 charger just stays on a green light an dos not charge the battarry
Hilti 22-a
The problem here is it could be either the battery or the charger, most of the time it's the charger. The only way to check is to try charging your battery on another charger or try charging another battery on your charger. If you have two batteries this is easy, if not you have to find a service center or someone you know with the same battery and charger to find out which is bad.
Jul 18, 2012 | Hilti Drills
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
My 36v cahrger is not charging ?
THERE IS A SMALL WHITE FUSE INSIDE THE CHARGER CHECK TO SEE IF IT HAS BLOWN IF SO REPLACE WITH A NEW ONE THE EXACT SAME AS THE ONE YOU ARE REPLACING BUT REMEMBER TO UNPLUG EVERY TIME YOU WORK ON IT OR ANY OTHER ELECTRICAL EQUIPMENT STAY SAFE UNPLUG EVERY TIME YOU WORK ON ELECTRICAL ITEMS
Feb 28, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
Hilti c7/36 I am looking for a electronic diagram
if the light on the charger are functioning ok. the problem is most probly the batterys. they dont last forever, replace the batteries and you should be ok.
Jul 20, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Jul 19, 2009 | Energizer NiMH Compact AA/AAA Battery...
Hilti 285359 SF 121-A 2.0 NICD Cordless Drill/Driver Logo
35 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
