Question about Smooth Fitness Smooth Agile DMT Elliptical Trainer
Timer keeps pausing every 30 seconds
It will not run programs but all functions work otherwise
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
How do I change the clock on a oxo digital timer?
I'm assuming that you're referring to OXO's Digital Timer Model #1061978. OXO doesn't provide a copy of the instruction booklet for download, but I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Aug 19, 2014 | Hardware & Accessories
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Mar 26, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
I have a GE Heavy Duty Digital Timer product # 15117. It also says it is a Jasco Product. I am having a problem getting the clock function to work. I can set the time yet I do know see where there is an...
My auto function on my GE outdoor timer didn't work orginally. So, I programmed the "on" time to be 5 minutes from the current time (10:15 p.m.), and the "off" time to be the time I wanted (10:30 p.m.). Then I put it on automatic and waited for 10:15 p.m. to arrive. It turned on. Then, I set the "on" time to 5:30 p.m. and it works fine now. Apparently, it has to cycle through the "on" time in order to activate the auto function.
Dec 10, 2010 | Garden
My XPS M140 is slow. It pauses for no reason
If the system is pausing for 10-30 seconds , there could be some bad sectors on the harddrive or , there are some unwanted programs running in the background
To check if your hdd is working fine
1. restart your computer
2. And press the F12 key slowly 5 times
3. Run onboard diagnostics on the hdd.
Thanks for using Fixya
Proton
Oct 18, 2009 | Dell Inspiron XPS M140 Notebook
Smooth Fitness Smooth Agile DMT Elliptical Trainer Logo
64 people viewed this question
Top Smooth Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smooth Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
