Question about Compaq Presario Notebook
I pressed something last nite now wen i want to click on any thing i have to right click it instead of taping the touch pad thing
  • 535 Answers
U need to restore your system at privos date u have do this go in start>program>assesoris>system tools>system restore
restore your system in priovs date your pc will be normal
Posted on Jan 10, 2009
How do I turn off the nightlight on the bottom of my microwave?
TheAuto Nite Light feature can be set to turn on and off at any time desired.Follow the directions below for set-up:
  1. Press the AUTO NITE LIGHT pad.
  2. Enter the time the light is to turn on. ...
  3. Press the AUTO NITE LIGHT pad again and enter the time the light is to turn off. ...
  4. Press the AUTO NITE LIGHT pad once again.
Sep 16, 2017 | Microwave Ovens
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
My mouse pad cursor do move but it doest whant to enter if i tab on it
some touch pads have a setting that must be set to allow a tap to be interpreted as a click. Go to Start-->control panel-->mouse, and look for a setting that tells the touch pad to allow it to sense clicks on the touch pad instead of requiring a button to be pressed. If not, try updating your touch pad driver. Start, right click on computer, click on Manage, when computer management window opens, click on the device manager in the left pane. Find mice and other pointing devices in the middle pane, and click the small triangle to the left of it, to expand it. Find the one under there that stands for your touch pad, and right-click on it, and click "Update Driver software." make sure you are connected to the internet first, and let it connect to Windows Update to see if it can find a newer driver.
Jun 24, 2011 | Lenovo 3000 N200 PC Notebook
The whole screen is now tiny..i may have pressed something last nite but cant remember as i was drunk.lol..thanks again
There are a couple of things to check. If you have a "zoom" button on your keyboard, you can try pressing +(;larger) or-(smaller), you may have to press "CTRL" at the same time. you may also have the option to click on the "tools" icon, in upper right in taskbar, it may look like a gear. Right click on this abd, if you see a zoom option, click on that and pick your size. Another place to check is in your "control panel". Right click on "personalization", then "display settings". look at your resolution "slide bar" and if resolution is too high, no higher than 1024 x 768, slide it down some, this will shrink the size of display. If this does it for you restart. If this doen't do it for you click on "adjust font size(DPI). You should see "smaller font" with an empty box next it it. If the box is empty, click on that, then "apply", lower right, Then ok. You will have to resatart to make this take effect. That's it.
Dave
Jun 21, 2011 | Computers & Internet
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
How do i turn off the touchpad on my acer aspire 5532
HI,
Please find the steps to disable the touch pad for your laptop.
Follow the steps below to access device manager and disable touch pad.
  1. Click on Start.
  2. In the Start Search Box type devmgmt.msc and press enter.
  3. Expand Mice and pointing device.
  4. Right click on Touch pad and Disable it.
  5. Restart the computer and verify if it works fine.
let us know if you were looking for something else.
Jan 20, 2010 | Acer Aspire AS5520-5537 Notebook
Coby mp3 player touchscreen wont work
to fix this problem go bak to calibrate and the screen will go blue and in the corners you will see a cross hit the crosses in order in 3 sec or less and the mp3 will go back to touch screen! if it works let me knoow via email gaudettemichael3@gmail.com
Dec 25, 2009 | Audio Players & Recorders
How do I turn the synaptic touch pad off on my acer aspire
This should be an easy fix...after many months of trying to disable touchpads on machines that did not have the one button disable feature either in the control panel or on the touchpad itself I discovered it was one of the function keys.
Press function (FN) and the "F7" key...press again to re-enable. Good luck!
Dec 21, 2009 | Acer Aspire 5100 Notebook
ZENITH VCR TAPE KEEPS EJECTING
Got pets or young ones? This problem just smacks of having something lodged inside. Could also have come from a label coming off inside, too...accordianman
Jan 19, 2008 | Zenith VCS442 VHS VCR
Compaq Presario Notebook Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
