Question about Pyle PLCD55 CD Player
Bad performance radio is on but sound cuts on and off, also cd player skips
    President:
  • 3,130 Answers
You will need to double check your installation my friend, such as make sure all of the power connections are good. If that does not correct the problem, most likely you have a problem in the radio and these days you can get a good Sony or Pioneer in dash with a cd for around a hundred bucks or so. Good Luck
Posted on Jun 05, 2007
CD player skips even though the same cd does not skip in other cd players
The laser in the cd player is most likely faulty or dirty. Buy a cd laser cleaner.
Aug 02, 2014 | Coby Cxcd248 Portable Cd/Cassette Player...
Skipping music and CD player not woring
CD scratched at all??
Most likely the read arm motor is going bad and replacement of the radio will repair it........ if the CD is not scratched. have you tried other CD's??
Jun 13, 2013 | Honda Vehicle Parts & Accessories
Hello, pls my system if is playing the sound would cut off and pickup after some minutes while the counter on the cd player is counting which indicates that is playing but no sound,when is like this i...
When the sound cuts off just hit the side of your main system with your fist. Do it with the radio playing or the CD will skip and get damaged ( Remove all the CDs from the system ). If the sound comes back when you hit the system, there is a dry soldering in your system for which you will have to take professional help. Please check if the Fan at the back is working. Dry soldering occurs because the system is running very hot. Poor ventilation or Fan failure.
Mar 10, 2011 | Samsung HT-DS1000 System
2005 Harley Ultra Classic, CD player skips
Dampers or laser have started to give up. Contact Radio Sound for a possible repair www.radiosound.com
May 24, 2010 | Harley Davidson 426290 AM/FM Radio
CD player problems in 99 Silverado
INTERNAL MALFUNCTION OF THE RADIO.. CHEAPEST SOLUTION TO THIS PROBLEM IS TO REPLACE THE RADIO WITH EITHER AN AFTERMARKET RADIO OR A USED RADIO FROM A WREAKING YARD.
Apr 11, 2009 | 1999 Chevrolet Suburban
Durabrand CD Home Music System Model hm3817dt
If the unit is not under warranty then you can open it and have a look inside. Keep your eyes peeled for bad soldering joints and if it is dusty clean it out.
However if it is under warranty and you open it, then you will break the conditions of the warranty and if it needs repairing then you will be charged the full amount.
May 28, 2017 | Audio Players & Recorders
Cuttinng out
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Jun 07, 2008 | Pioneer DEH-P6800MP CD Player
Pyle PLCD55 CD Player Logo
87 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
