Question about Neff U1721 Double circotherm Electric Oven
Changing an element on the main oven - Neff U1721 Double oven
Do I need a special tool to remove the fan to gain access to the upper fixing for the element, please ?
  • Neff Master
  • 3,463 Answers
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
  • stevensp56
    stevensp56 Apr 13, 2013
    Need to remove screws from back cover need to know what size tool to use
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Tip
Common Heating faults Neff U1721 Electric Oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 17, 2009 | Neff U1721 Double circotherm Electric Oven
Fitting a new heating element Neff U1721
You need to remove the element from inside the oven cavity, but it is a bit of a fiddle. Once you have removed the screws at both ends of the element you need to remove the fan blade to access the centre fixing screw. Once all srcews are remove you have to twist the element and pull forward to remove the wires from the hole on the left, then remove the wires and refit to new element.
Jul 11, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Jul 09, 2008 | Neff U1721 Double circotherm Electric Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
459 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
