Question about Dell White Slimed Inspiron Mini Nickelodeon Edition Netbook PCwith Intel Atom Processor Windows XP
Dell nickelodeon mini no sound
I bought this second hand and there is no sound. the guy told me he restored it to factory settings, but something is wrong. i looked to adjust the volume but it is all shaded out, and you can't click on it. because we havent' used it yet, i want to do another factory setting reboot, but when i use the control f11 duo, nothing happens. i have all the disks and an external drive, should i restore it that way?
  • 37 Answers
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Posted on Jan 06, 2009
  • 50 Answers
SOURCE: I want to restore my dell laptop to factory settings
you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Posted on Mar 25, 2009
  • 3940 Answers
SOURCE: loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Posted on Jul 13, 2009
SOURCE: howcan I restore my Dell Mini Notebook to factory
You can restore your Dell Mini using Using Dell PC Restore in Windows XP or Dell Factory Image. You can successfully restore your computer yourself. All you need is to download a manual containing instruction on how to restore. Download the manual from http://support.dell.com/support/edocs/systems/ins1010/en/index.htm
See pages from 37 - 43. You can restore your computer on your choice.
Cheers!
Posted on Apr 01, 2010
  • 185 Answers
SOURCE: how do I restore factory settings on my dell
  1. Restoring a Dell System Running Windows XP.
    Turn off and reboot your computer. When you see the Windows flash screen, depress "CTRL" and "F11". Be sure to press them simultaneously and release them simultaneously.
    Select "Restore" in the "Dell PC to restore by Symantec" window and press "Enter".
    Highlight and select "Confirm" when the message shows that you wiill lose all data if you continue. This will begin the restore process. It usually takes about 10 minutes or so. When it's done, you should receive a message that states the system recovery process was successful.
    Select "Finish" to complete the process and restart your system.
  2. Step 6 Restore a Dell System Running Windows Vista
    Shutdown and restart your computer. Keep pressing "F8" until you see the "Advanced Boot Options" menu. You must depress the keys before the Windows Logo screen appears. If you wait until after the screen appears and then press "F8", it's too late and you'll have to reboot the system and try again.
    Navigate to the "Repair your computer" option
    Select the appropriate language and click "Next".
    Sign onto the system as an administrator. Without administrative privileges, you will be unable to perform the system restore.
    Select "Dell Factory Image Restore" and click "Next".
    Place a check in the check box next to the text that says "Yes, reformat hard drive and restore System Software to factory condition" and click "Next".
    Click "Finish" to complete the process. This will reboot your computer.
Posted on May 19, 2010
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Need to restore my 8 yr old sons dell mini nickelodeon laptop, its all screwed up
Have you tried using the RESET button? It should be identified as to
location in your owner's manual.
Aug 21, 2011 | Motorola Mobility OEM Bluetooth USB PC...
My inspiron 1018 won't boot. i need to reinstall or repair my software. it does not have a cd drive. please advice action.
The Dell Inspiron Mini 10 series of netbooks come with recovery software that can restore your netbook's original factory settings. Dell Inspiron Mini 10 netbooks with Windows XP, Windows Vista and Windows 7 can be recovered to the factory settings using a recovery partition on the hard drive.
Windows Vista or 7
Turn on or restart your Dell Inspiron Mini 10 netbook. Press the "F8" key repeatedly when the "Dell" logo appears on the screen to be redirected to the "Advanced Boot Options" menu.
Highlight "Repair Your Computer," and then press "Enter."
Highlight the language layout you want to use for your keyboard and click "Next." Enter your username and password if prompted. Click "OK."
Click "Dell Factory Image Restore," and then click "Next." The recovery software on some Dell Mini systems may require you to click "Dell Factory Tools" followed by "Dell Factory Image Restore" and "Next."
Click "Next" if you understand the netbook will be restored to its original factory settings. The recovery process will begin.
Click "Finish" when a message appears saying the recovery is complete. The netbook will restart and boot up to the Windows Vista or Windows 7 set-up screen, where you can begin personalizing your netbook.
Windows XP Recovery
Turn on the computer. Press the "Ctrl" and "F11" keys at the same time while the computer is booting up to access the recovery software.
Click "Restore."
Click "Confirm" to begin the recovery process, which shouldn't take longer than 10 minutes.
Click "Finish" to restart the computer and finalize the installation. Click "Yes" to restart the netbook again. The computer will boot up to the Windows XP setup screen
Here is a link which will take you to the site which will allow you to download a ZIP file with a WEB PAGE type service manual for your 1018, after a 45 second wait. (They want you to sign up for premium service but NOT NEEDED) Click again after wait?
After download, open the ZIP file and copy all contents to a new folder. Double click the Contents.html file to open in a web browser, then use the built in shortcuts to navigate the manual.
http://www.laptopmanual.net/manual/Download_Dell_Inspiron_Mini10_1018_Service_Manual/2846/1
If you like this - Please vote.
Jul 25, 2011 | Computers & Internet
Purchased Inspiron Mini 1012 Win 7 Started - was told it was new, but is not. How do I restore it to its original factory settings?
Hi suscarsimba,
Welcome to FixYa! How are you doing?
Please try the following steps:
  • Tuen on your computer, Start tapping the F8 key repeatedly until the Advanced Boot Options menu appears on the screen.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  • Specify the language settings that you want, and then click Next.
  • Log in as a user who has administrative credentials, and then click OK.
  • Click Dell Factory Image Restore.
  • In the Dell Factory Image Restore window, click Next.
  • Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
  • Click Next. The computer is restored to the default factory configuration.
  • When the restore operation is completed, click Finish to restart the computer.
Hope it helps. Thank you for using FixYa.
Apr 21, 2011 | Dell Inspiron Mini 1012 Netbook PC
Format dell mini 10
Hi
Do you really need to format your laptop
have you thought about or tried a system restore back to when it was ok
or back to last good know configuration
factory restore is so very permanent and you will loose any thing and everything that
you may of put on there like files or photo's
Because it will take it back to as you ist bought it and it will take a ages to set it all up again
how you liked it
But perfect if that is what you want
so please do burn anything to disk using a exterior drive or at least send over to a pendrive
or spare exterior hard drive
and to restore back to factory settings i believe that when you hit the power start up key also hit the F8 key at the same time and it should take you into the factory restore manager
then follow the on screen directions
good luck
many thanks
Mar 07, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini Laptop 1012, how do you set it to factory seting?
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Jan 05, 2011 | Dell Inspiron Mini 1012 Netbook...
Howcan I restore my Dell Mini Notebook to factory
Cheers!
Apr 01, 2010 | Dell Inspiron Mini 10 Notebook
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell White Slimed Inspiron Mini Nickelodeon Edition Netbook PCwith Intel Atom Processor Windows XP Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
