Question about Jl Audio 250/1 Car Audio Amplifier
Jl 500x1audio comes on but turns off after a few sec powering 1 w6 jlaudio
    Problem Solver:
  • 17 Answers
There is a internal problem with it.Or it is not hooked up poperly.
Posted on Nov 27, 2012
5 Suggested Answers
  • 231 Answers
SOURCE: how to connect it
bridge the amp and wire the JLs in parallel..then put some earplugs on ..lol
Posted on Dec 24, 2007
  • 14 Answers
SOURCE: JL 500/1 loses power after 15 seconds
that sounds like a ground problem. make sure that the wire is grounded to your frame, or any other unpainted metal surface. if no unpainted surface is available, get some sandpaper, and 2 gold, copper, or silver washers (in order from best connection to worst) from your local hardware store. find a bolt near the amp, that wont make something fall apart. take the bolt out, and sand the paint off underneath it. make sure to get all the paint and primer off. put the 2 washers on the bolt, and put the ground wire between the washers. then tighten the bolt nice and tight. this will give you the best possible ground connection, without running the ground to the neg of the battery. if this still doesnt work, try running the ground to the neg of the battery. if that doesnt work, then you should have your amp looked at. hope this helps
Posted on May 01, 2009
  • 149 Answers
SOURCE: jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Posted on May 12, 2009
  • 84 Answers
SOURCE: 1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Posted on Jun 14, 2009
Box size for jl audio 12"w6 going in large trunk
call jl they will give you BEST box recommendation
Jan 24, 2013 | Car Audio & Video
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
Apr 23, 2012 | Jl Audio Car Audio & Video
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
Can you push a w6 with a 1500 phantom boss amp?
I can assume that phantom 1500 is a 1500 watt amp? but still the amp will have more than enough power to push a w6, w7,and even in pairs. Single w6 can handle 600 watts rms, thus you will need to turn the gain all the way down so that the speaker won't over powered and that can lead to breaking the sub.
Dec 12, 2010 | Jl Audio 12W3 Car Subwoofer
I need to wire two w 7 svc ten inch subs to a 1 ohm load
jl didnt make w7 svc but i will include a wiring schematic from jl for the w7......http://mobile.jlaudio.com/support_pages.php?page_id=145
Aug 26, 2010 | Jl Audio 12W3 Car Subwoofer
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
Jl audio w6 surround repair
If you're willing to do the repair yourself, there is an Internet site - Simply Speakers -that sells repair kits for speakers ,including speaker surrounds.
I did two 10" drivers and it worked 100%. ..
Jun 05, 2009 | Jl Audio 12W3 Car Subwoofer
Mid level volume my sub starts poppin
Set your gains correctly. You are overdriving the sub, causing the voice coil to bottom out. Go to www.jlaudio.com and go to the support / tutorials section and it will have a tutorial in there that will tell you how to properly set your gains. The same information is also in the owners manual that should have come with your w7, and probably also says how in your amplifier owners manual.
May 31, 2009 | Jl Audio 1000/1 Car Audio Amplifier
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
My jl Auido 250/1 amp
You may have a bad output on the amplifier. I would recommend taking it to a local electronics repair to have fixed, or visit a local stereo shop - preferably a JL Audio dealer. Visit their website at www.jlaudio.com to find a dealer near you. You can have your amplifier sent in to JL Audio for repair by an authorized dealer and you'll get a warranty on the repair work.
Sep 27, 2008 | Jl Audio 250/1 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
37 people viewed this question
Top Jl Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
matthew walsh
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
