Question about KitchenAid 24 in. KUDK02CR Built-in Dishwasher
Kitchen aid dishwasher KUDK01ILBS1
This is the second time my dishwasher has completely stopped. The green light on the right front is flashing but nothing else happens when I press the buttons. The owners manual indicates this might be the heater element but I need a little more help than that because when I search for that part it does not exist. Thank you any adise you might have. Tammie
  • 641 Answers
The heating element looks like a big metal pipe and located on machine's bottom (not inside the cabin). Good luck !
Posted on Jul 20, 2007
Flashing start light
I'm assuming it fills with water, & then stops?
If the pump runs for a few seconds then stops it could be the flowmeter is blocked. This is in the tank bottom right (under the drain plate) & has a black grille in front of it.
Can be cleaned by a toothbrush or a quick spurt from a garden hose!
If no pump is heard, then it could be a faulty pump.......
Hope this helps.
Mar 04, 2013 | Whirlpool DU1030XTXQ Builtin Dishwasher
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Sep 26, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Kitchen Aid dishwasher won't start
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Jul 02, 2008 | Dishwashers
Dishwashers Logo
112 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
