Question about HP Compaq Business Notebook NX9010
Screen Problem My screen just went black (no spark, no smoke, no nothing) the time I put it on, someone says that one of the fuse on the screen is bad and current passed through (doesnt sound electrically correct). It just wouldnt come on exept on an external monitor. the fuse he's talkin about is dark while the other is cream/brown. Pls help me out
  • HP Master
  • 19,396 Answers
"one of the fuse on the screen is bad and current passed through"
Well , that is quite approximative, but there is some truth.
If display is not coming on then there may be three common faults causing this:
  1. LCD DISPLAY
  2. INVERTER/BACKLIGTH
  3. RIBBON CABLE
  1. LCD DISPLAY
    This is the display panel itself , when it is defective, you get no picture.
  1. INVERTER/BACKLIGTH
    The inverter is the electronic board that powers the back ligh lamp. When the inverter is faulty you get no backlight, and very dark picture, or no picture at all. The inverter is not an expensive part, but must be tested before replacement.
  2. RIBBON CABLE
    This is the cable that connects to the LCD display, carrying power and video signal. If it is broken or misplaced you get no video.
Posted on Jan 10, 2009
    Sergeant:
  • 431 Answers
I hope fuse will not be provided in laptops check the signal cable with multimeter
Windows 2000 xp will not boot up
Quite possibly your hard drive is either bad or going bad. I hope you have a backup of your stuff.
Oct 01, 2017 | Pioneer Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Screen went black after hearing poping noise and seeing smoke. The vizio light will turn off and on but screen remains black without sound.
Your power source or projector has definitely short putted, i would recommend replacing the parts.
Jun 24, 2010 | Televison & Video
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
GE D52GW12 - Manufactured in 9/2004
dear one
your pl check following point's
1 check mains power plug is all right
2 if you can check by changing the main's coard
if your problem not solved call the service persone the probleam is with main poer supply in your tv.
thank you
Jan 24, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Gateway laptop
Doesn't sound too good - Could be a bad ram chip (right on the bottom of the laptop under a panel - try removing one or the other chips) or possibly bad motherboard (which is definately not worth it on a several year old gateway machine if you could even find one)
Let us know if the ram does it.
Dec 27, 2007 | Gateway M305CRV Notebook
Panasonic 32" flatsceen tv
Not an easy fix because of the smoke which means that there is a short from a bad ground that may have blown a capacitor because of a loose connection. Often a short on the circuit board results in having to get a new one because of damage from the sparks. Make sure it is unplugged at all times until someone can open it and look. With any luck, the damage is light and the loose wire can be re soldered at minimal cost.
Oct 30, 2007 | Panasonic CT-32D12D 32" TV
Tv screen Faulty
It's always a bad sign when the magic blue smoke is released from inside the TV set. I would suspect a defective capicator has blown its' top. When the screen went black, did you lose audio also? If you still have audio, it's possible that resistor R587 Opened up which would smoke, (1.5k 1/4 W) And D518 Shorted (Nte558) If you lost audio as well, then it could be a shorted Vertical IC pack. If you're not up to testing and replacing components, the set will need to see a repair shop.
Jan 01, 2007 | Sony KV-27S20 27" TV
HP Compaq Business Notebook NX9010 Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
