Question about Dryers
My 2 H.P. electric motor on the Task Force 5 ton log splitter hums when I depress the start button but will not tturn
  • Dryers Master
  • 8,220 Answers
It probaby is the capacitor. Check for a loose connection or burnt wire on it. Use an old timey el cheaper meter on ohms to test it. Remove the capacitor being careful not to discharge it and check between the terminals. If you see a slight hop while reversing polarization then the cap is fine. If it has no reading it is open inside which is probably the problem. If it was shorted then the needle on the meter would move over and stay and that would cause the circuit breaker to flip everytime you try to start it. Probably a bad capacitor. Easy fix.
Posted on Nov 27, 2012
SOURCE: electric kenmore dryer
service tech came to the house to fix it and discovered it was the relay switch, not the circuit board like the previous tech said and ordered the board which took a week. Anyways the relay switch did the trick. I hope this saves the next guy some trouble. Thanks
Posted on May 21, 2008
IrishDruid
  • 2712 Answers
SOURCE: I have a electric dryer
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in? Ifyou plug something else into the outlet, does it work? If not, checkfor a blown fuse or tripped circuit breaker.
Door switch Ifthe door switch or the door-switch actuator is defective, the dryerwon't work and you need to replace the failed component. The switch isinside the dryer main housing near the door frame. Sometimes you needto raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, yourdryer either just stops heating, or it doesn't work at all. Be sure toinspect the venting/heating system before replacing the fuse to put thedryer back into operation. (You can't re-set this type of fuse.)
Wiring Oftenthe main wiring connection from the house, at the dryer, burns and theconnection breaks. In this has happened to your dryer, you need toreplace the power cord and the terminal block inside the dryer to whichthe wire is attached.Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
  • 864 Answers
SOURCE: Model DLE3777W - Dryer hums when I push start button.
The drive belt for the drum may be broken and should be replaced.
Posted on Jul 18, 2009
protek480
  • 1714 Answers
SOURCE: When the start button is depressed the drum will
The capacitor that starts the motor is bad
Posted on Jul 25, 2009
  • 35 Answers
SOURCE: Push start button and motor hums.
thermal overload on motor tripping
Posted on Jan 26, 2010
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
Can i run my hydrolics at 34000rpm with a electric motor?
I think you mean 3400 RPM not 34000. The 3400 rpm electric should work if the horsepower rating is enough.
Sep 17, 2014 | Swisher 10 Ton Hydraulic Manual Log...
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
Just got a log splitter cantget started motor running it moved and blew fuse
Hi, not much info to go on here, but;
have you ensured that your outlet automatic fuse (if applicable) will handle the current of the electric motor? Check ratings. If motor rating is close to automatic fuse limits, you will need a "slow" type auto fuse or use a larger capasity outlet. This the first thing to check before looking further at the splitter itself, assuming that it is the fuse of your outlet that you blew?.
Kjell
Jul 14, 2011 | McCulloch 4 Ton Electric Log Splitter #...
5 ton electric woodsplittr wont return to start
look for a limit switch that might have debri in it not allowing it to read properly.
Mar 15, 2011 | McCulloch 4 Ton Electric Log Splitter #...
Splitter (2 years old) motor won't shut off.
First of all, I hate to, but have to ask, have you verified oil level is up to proper level? Have you checked power at directional solenoid when handle is moved to different directions, as well as released? Obviously when handle is in stop position, there shouldn't be power to motor in either direction. I can't see exact model, or design obviously,but that would be a good place to start.
Jan 31, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Was just curious if the 4ton 2hp electric wood splitter was 110 or 220...hopefully 110 as I just ordered it for hubby!
Sorry but I think it will be a 220V motor.
They do not advertise the voltage very well and I had to do some digging to find that the motor pulls 12.5 maps which would make it a 220 v motor. At 110v a 2 Hp motor would be pulling 20 amps or more which would still make it too much for most household circuits.
Running a new line for your splitter should not be a big project for most electrictians... Also if your husband has a gas generator most of them will run that splitter and then it would be portable...! Just load up the generator and the splitter and he can split anywhere...
Heatman101
Dec 30, 2009 | McCulloch 4 Ton Electric Log Splitter #...
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Dryers Logo
120 people viewed this question
Top Dryers Experts
