Question about Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
Hi! I was in the middle of washing clothes and it seemed like I had loaded too much and the spinny thing was working harder and harder to wash and eventually it stopped after about 2 minutes. I stopped the wash completely and found some clothes had wrapped themselves around the spinny thing (sorry don't know correct term) took them out unplugged the whole thing and it is still not working. What could it be? Motor or something? It is an electric washer Whirlpool extra large capacity 7 cycle probably around 10 years old. Please help! My clothes are soaking wet!
  • MrCaesar May 11, 2010
    So the clothes wrapped around the agitator? Check under the washer and see if there is black crumbs underneath.
  • 150 Answers
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Posted on Jan 30, 2009
Whirlpool GSQ963ILL0 top load washer. Stopped dead in middle of agitate cycle. I fear I overloaded it. Now just sitting, full of clothes and water, and won't do anything. Any advice?
Hi jim_zervas,
Firstly, unplug the machine. Then first thing to do is remove the clothing, and bucket the water out. Then run the machine again.
Let me know what happens?
Kind Regards
JEDEMEYER1
* Please accept my solution if it solved your problem
Sep 03, 2011 | Whirlpool GSQ9631L Top Load Washer
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Problem is the washer stops and F 11 dl come on and it stops midwash
The problem is the CCU circuit board at the inside top back of the machine. The circuit board has cold solder joints where the relays (5 of them) and the spade connectors connect to the circuit board. Touching-up these points will eliminate your code problems.
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I hate my Whirlpool Cabrio washer- I've had it for almost 4 yrs- digital display board broke at 2 1/2 years and cost $450 to repair. Now I have leak under the washer who knows how much it will be to...
I also hate hate hate my Cabrio washer and dryer. I've been a loyal whirlpool customer for over 25 years with ALL my household big appliances. ThWhirlpool doesn't care about loyalty. I bought this washer and dryer set in Sept. 2010. The clothes don't get clean....the darks have white streaks on them. I have to re-wash about every other load. I washed a pair of jeans and they still had dirt on them when I pulled them out. I called Whirlpool and their response was "What do you want me to do about it?" They said they can't do anything bc the washer is an energy saver.. I will NEVER buy another Whirlpool appliance.
Sep 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
It eats my clothes
I would remove the agitator, checking to see whether the bolt that holds it to the drive shaft is securely tightened. If it is tight I would then check the agitator for a serial number, usually molded directly into the plastic agitator on the inside bottom. Use the internet to determine if the part is the correct agitator for your specific model of machine. I have seen the wrong agitator installed on machines before and it can do a number on clothes, especially sweaters.
Dec 14, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Logo
561 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
