Resetting alba radio control wall clock - Audio Players & Recorders
3 Suggested Answers
SOURCE: Need manual for Alba Clock Radio CRDAB301
Sorry m_gerard, I can't help you with the manual.
However here is a partial list of operations for the Abla CRDAB301:
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Switch the radio on;
  • Press and hold MENU for 2 seconds
  • Press SELECT.
Switch between FM and DAB:
  • (radio must be on)
  • Press DAB/FM
Tune & store all DAB stations:
  • Press MENU
  • Press ">" three times (or until display says "Autoscan full")
  • Press SELECT
To listen to another DAB station:
  • Press "<" or ">" until the station name is displayed
  • Press SELECT
Hope that helps!
Posted on Aug 22, 2009
  • 71 Answers
SOURCE: global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Posted on Mar 16, 2010
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
I need the instruction manual for the TRDAB2822 Alba DAB Digital Radio, where can I find this please?
Go to Alba's wed site and look for downloads where you should find operating instuctions.
Jul 25, 2010 | Audio Players & Recorders
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Instructions for setting alarm on Alba PD2 DAB/FM radio Thanks.
Hello All,
I have an Alba PD2 DAB radio and have set the alarm to come on with the radio. The problem is it comes on at a very loud level. Is there a way to set it at a lower level ??
Dab Des
Jan 03, 2010 | Audio Players & Recorders
Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Press SELECT.
  • Press DAB/FM
  • Press MENU
  • Press SELECT
  • Press SELECT
Hope that helps!
Apr 20, 2009 | Audio Players & Recorders
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
102 people viewed this question
 Grubhead
Grubhead
