Question about Lenovo G560 (0679-AKU) NoteBook Intel Core i3 380M(2.53GHz) 15.6' 4GB Memory DDR3 1066 500GB HDD 540...
Lenova system when on but not for booting - Lenovo G560 (0679-AKU) NoteBook Intel Core i3 380M(2.53GHz) 15.6' 4GB Memory DDR3 1066 500GB HDD 540...
  • Lenovo Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Nov 28, 2012
Where are computer settings on a Lenova desktop computer?
Could you please provide a little more info? What is the operation system you're running (ie, Windows XP, Vista, 7, 8, Linux, etc), what settings are you looking for (BIOS settings (for example, maybe you want to change the default boot device from a hard drive to a DVD drive so the computer tries to boot off the DVD drive first), power saving settings, device settings, windows update settings), etc. Also, perhaps the model number of the Lenova would help depending on what settings you're actually looking for.
Jun 25, 2014 | Lenovo Computers & Internet
My lenova laptop BMR is compressed, what's the solution for it?
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 20, 2013 | Lenovo 3000 G530 Notebook
I wnt 2 install widows 7 in my lenovo y 410 54Q note book... i want drivers for installing windows 7 62 bit or 32 bit drivers needed
Firstly go to Lenova's web site and make sure that Win7 supports Lenova 3000. If it does, check 64 is supported.
If all is OK, download the 64bit drivers to a USB flash drive or burn them to a cd.
Back up all of your data!!
Put Win7 64 system disk in your DVD drive and boot from that.
Follow the prompts and be certain to install A CLEAN INSTALL.
If you don't you will bring problems with you from your old system.
When Windows has finished installing, go through all of your programmes, installing them, as you have an empty drive to put them on, then install the 64bit drivers from your CD or USB drive.
Good luck and I hope this helps.
Nov 23, 2010 | Lenovo 3000 Y410 Laptop
I use windows 7 operating system on lenova ideapad U350 keyboard and mouse is disabled : it is not detected after boot:
It is easy to use and you do not have to change the settings for it to do its job, it can adapt its charge in the Dell Inspiron 6000 battery, it is re-fueling and, once the battery is full, this is converted into a pulse charge.
Nov 15, 2010 | Lenovo Ideapad U350 Laptop Notebook
Boot sequence problem while booting
your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Jul 27, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Webcam is not working (lenovo4152(B3q))
Check the driver for the webcam on the manufacturers website, most drivers for vista and xp are found on the websites.
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Lenova N100, Screen Blank
can you push the f2 or delete key when first starting computer, If you get a bios screen you want to reset the computer to factory settings just follow the directions in the bios to reset to factory default, You may also want to try the Blue FN key lower left hand side, and the f8 key at the same time let me know if that works for you
Dec 24, 2007 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo G560 (0679-AKU) NoteBook Intel Core i3 380M(2.53GHz) 15.6' 4GB Memory DDR3 1066 500GB HDD 540... Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
