Question about Stanton C.313 CD Player
My pitch control is broken
When I try to mix the red light flicks on and changes to a different speed and pitch setting all by itself.
    Sergeant:
  • 344 Answers
Take it in to have repaired,
Posted on Nov 29, 2012
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
I am new in to djaying and i bought a stanton mc 203 which s still in ood condition but my problem is the speed on the right cd keeps n changing time and again unlike on the left cd and this sometimes...
well the cd speed problem is about the components been under alot of use, they get worse with time. I'm not sure I think you should be able to lock the speeds somehow.
Jul 07, 2008 | Audio Players & Recorders
There are 2 problems with the my deck: 1. The +-0 light for the pitch will not work but everything else about the pitch works fine. 2. The deck will not change from 33bpm to 45bpm, I have replaced the...
Hi, please do this test for me. With the deck running on 33 speed and the pitch control set to 0 use your finger on the platter centre and speed it up manually as much as you can. Doe's the quartz lock lamp come on? If not then open the deck up and loosen off the fixing screws on the circuit board that has the 33/45 buttons. Try to change speed with the board loosened off. If none of the above makes any difference replace the quartz lock neon. Use only original Technics neon. As a matter of interest have you done any mods to the deck? Cheers John,
Sep 29, 2011 | Technics SL-1210 Turntable
Should i take it some where to change the pitch controlers or could i do it myself?....
what do u mean change the pitch controllers? you cant change the pitch controlers its set into the motor or your techs. if its broken have it sent out and fixed. dont try to do it yourself unless you are 1001% sure you know what you are doing
May 27, 2011 | Technics SL-1210 Turntable
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
Speed is inconsistent
if it does not brag about being "direct drive" on the front of the unit, then it is probably belt driven
http://www.archive.org/details/Turntable_Belt_Installation
will help you remove the platter to check the belt. if it is slipping it is the most likely cause.
Feb 16, 2009 | Audio Players & Recorders
When I plug in VGA there is a green mask or Hue, over the whole screen... I tried changing the settings but its not controllable with colour settings
I would try a different VGA cable, if you are using a VGA to component cable (VGA on one side and red, blue and green on the other end) you can just have the cables mixed up, make sure red is with red and so on
Aug 18, 2008 | Televison & Video
Technics SL1200 MK II Speed problem
this one happend to me!! try taking the plastic cover off, under the platter and removing the screws that hold it on if that cures it its because what you ll find is that the screws just catch the underneath of the platter as it rotates. happy mixing
Dec 28, 2007 | Technics SL-1200 Turntable
Stanton C.313 CD Player Logo
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
