Rowe ami r80 jukebox is exepting selections but keeps reapeating
Jukebox was workitionsng fine until i changed some records .it is taking selections but keeps reapeating the same record even when rejected
  • Anonymous Mar 12, 2014
    Bal ami junior wont select records or work
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
I don't have a manual handy but it could be a few things, you may need to reinitialize the jukebox, maybe there is a dirty wiper or the control module may be on its way out. I would try to locate a repair manual for it, there might be an old vending company in your area with one.
Posted on Nov 28, 2012
SOURCE: Rowe cd jukebox
See your manual on how to enter SERVICE MODE. When you enter it the display will show SERVICE MODE. Then type, hold and push, or push the keyboard keys as follows:
Type 20 - display will show ATTRACT MODE ON
hold RESET key down and then push 9 key - display will show ATTRACT MODE OFF
push POPULAR key
The problem should be fixed and you can shut the door and resume normal operation.
Posted on Jan 15, 2009
Testimonial: "Thanks very much!!!!!"
SOURCE: I just bought this Seeburg
the reject switch on the mechanism is stuck or bad its right next to the tone arm
Posted on Aug 01, 2008
  • 195 Answers
SOURCE: rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 211 Answers
SOURCE: Wurlitzer 1800 jukebox, plays record
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Posted on Jun 25, 2009
sirdotcom
SOURCE: I have rowe ami jukebox Eagle Laser Star and its
No don't do that. Take it to someone who services amps. They're all pretty much the same. Usually a couple of final-stage transistors are **** or the power supply is troubled. Good luck though!
Posted on Aug 19, 2009
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
We just bought a 1974 ami, plugged it in and it pl...
If your Rowe Ami is indeed a 1974 model it will be a TI-2 or CTI-1 (chest style jukebox) this era of jukebox uses a search unit to push out selected pins on the unit A side and B side for the mechanism to search for and play.
If the search unit is pushing out the correct pins but the mechanism is not scanning to select those selections, it could be that the mechanism is skipping over the pins or it could be that the search unit is not pushing out any pins at all with the search unit motor just spinning around.
If you are in the UK then I could help you.
If you are in the USA try posting a request for help on www.phonoland.com or on www.collectingbanter.com
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
May 20, 2010 | Vintage Jukebox External Speakers Shelf...
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont eject disc
Ouch!
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Rowe jukebox
CCC
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
401 people viewed this question
 Grubhead
Grubhead
