Question about Jupiter Microlite
Don't know how to reset Jupiter Microlite Ionizer's filter usage
Hi have had this filter for some time and recently replaced cartridge. The cartridge indicator light now needs to be reset so that it indicates when i will need the next filter. Please help. I don;t know how to do this and no longer have a manual. Many thanks.
  • uschi220 Jan 10, 2009
    Thanks ! That worked perfectly ! Problem solved.
    Problem Solver:
  • 6 Answers
Hold down the Purified and Acidic buttons at the same time untill all the led lights reset.
Posted on Jan 10, 2009
  • MrCaesar Jan 10, 2009
    I forgot to add you need to keep the water flowing trhough the Microlite during this process.
My xerox 6600 keeps saying "invalid black" when replacing cartridge
The CHIP on the NON OEM cartridge is NOT current with correct firmware and as a result the cartridge(s) will NOT reset that a new cartridge has been installed.
Future hint...do NOT update as working printer drivers "ever"...as this is one way that the OEM's thwart the aftermarket TONER usage.
Good luck
Mar 13, 2016 | Xerox Phaser 6600DN
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Toner Exhausted " I can
replace the whole toner cartridge. Refills won't help because SAMSUNG uses a chip(embedded in the cartridge) to monitor the cartridge usage.
Feb 03, 2011 | Samsung SCX-4300 Monochrome Laser...
Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
Thanks for using Fixya.
You won't need to drill hole anywhere.
Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
Visit this link to buy Universal chip reseter if you don' t have.
Good luck and have a nice day.
Jul 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Change a filter - lost manual
I advice you check the link below to search for the manual of your device, the link contain virtually almost all the manuals of all device.
manualsonline.com
Type the above link on your web browser to search for the manual of your device.
Take care.
Jun 28, 2010 | Jupiter Melody
I have speakers but thy do not give sound
easy way to test a speaker get a small 1.5volt battery then grab the speaker wires hold one wire on battery + then strike the other wire on - the speaker should make a noise
Apr 21, 2010 | Jupiter Microlite
Pixma MP150 Will not print. Error 2 says paper out.Won't print no matter how much paper is put in Recently replaced color cartridge. Have reset cartridge, shut printer down and restarted. Nothing works
Are you using a factory new Canon cartridge or a third party cartridge or even worse a refilled cartridge.
80% of the time, that's the failure.
Don
Feb 24, 2010 | Office Equipment & Supplies
No problem but can't find replacement filters for my Family Care air purifier/ionizer Model HAP221
Hi just a tip for you, if you can't find a filter you can buy filter media at your hardware store such as Home Depot, and have it cut to fit. It is good material made to replace any type filters. Sincerely,
Shastalaker7
Dec 04, 2009 | Family Care HAP221 Air Purifier
I want to darken copys on my canon pc850
it seems you used the cartridge upto 3 times usage. you may need to change the drum.
Feb 17, 2009 | Office Equipment & Supplies
Jupiter Microlite Logo
545 people viewed this question
Top Jupiter Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Jupiter Kitchen Appliances - Other Expert? Answer questions, earn points and help others
