I need a manual
I need to find a manual for my set top box
    Top Expert:
  • Televison & ... Master
  • 74,496 Answers
What is the Brand name and model number to your set top box?
Posted on Nov 27, 2012
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Need a manual or connection diagram for a AWA set top box Model No. 2030
Hi Anonymous, The link below is a FREE 10 page user manual for an AWA digital set top box model number 2030..........CHEERS..
http://cncms.com.au/AWA-IMs/SetTopBox/DT2030.pdf
May 02, 2016 | Televison & Video
I have a Palsonic TV model 4878. It has no av outlets. How do I connect it to my set top box? It appears to have what looks like a SCSI plug...
Please review your Owner's manual. and or your set top box. Ask your cable? supplyer customer service and or your set top box
Owner's manual.
Mar 18, 2015 | Televison & Video
With set up box audio in to tv causes high pitch sound
I am assuming this should read 'Set top box'. What kind of cable are you using?
Usually the set top box connects via a SCART lead but yours may be HDMI if it is a very new set top box.
If you are using RCA plugs, you may have cross connected the wrong cables. The RCA cables should be colour-coded. RED and WHITE are for audio, Yellow is for video.
Best advice is to switch it all off, remove all the cables you attached, and start again. The instruction manual/user guide usually has an illustration to help you identify what your set up looks like - there are usually several examples.
If the cables you need did not come with the set top box, you will need to purchase them.
When you are connecting audio leads, you should use the 'audio out' on the set top box and the 'audio in' on your TV set.
It would help to know the EXACT model number of LG screen you have and the make and EXACT model number of the set top box.
Good luck.
Mar 07, 2015 | LG 42LC2D 42 in. LCD HDTV
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I need to manually program my universal vizio remote
1. Manually turn on the VCR/DVD/Cable set top box.
2. Press the VCR/DVD/Cable set top box button on the remote control.
3. Press and hold the SETUP button until the LED LIGHT flashes twice.
4. Enter the codes using the Number Buttons. If the code is accepted, the LED flashes twice after the last digit is entered.
If the LED does not flash twice, repeat Steps 2 through 4 with the next code listed for the component and
manufacturer.
5. Point the remote control at the VCR and press the POWER button. The VCR/DVD/Cable set top box will turn off.
6.Your are done.
Thanx
Jul 23, 2010 | Vizio VR2 Remote Control
Need a copy of the instruction manual
how to manually tune a digital set top box tcl dst 8313
May 10, 2009 | Televison & Video
MANUAL FOR HD SET TOP BOX
Try this link. Ijust downloaded the manual from here myself.
http://www.dgtec.com.au/arbitrage/pages/134/DG2000A+UserManual.pdf
Regards
Graham
Jan 19, 2008 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
