715V1265-J/1 can't hold the source
It will not stay on tv or pc or av's souce
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
32" samsung hdtv flat panel: switches when you don't want it from tv to av/pc or av to tv/pc.
Sometimes, TVs will switch to a new input when they sense a new signal on the new input. So if you're watching TV and someone turns on the AV device (or makes a change that alters or starts a video signal), the TV may switch over to that signal. This is a function of the TV. Some TVs allow you to disable this function, others do not. I looked in the manual and didn't notice where this could be enabled or disabled. If you want to only watch one source, make sure the other sources are turned off.
May 14, 2014 | Samsung LN32A330 32 in. LCD TV
I have lg dvd model dv257 pm, problem is there is no audio and video output but reading disc is proper plz give me solution for it.
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | LG Televison & Video
How to connect austar and a blue ray DVD player to tv
Good luck.
Jan 04, 2012 | Televison & Video
No plug ins work other than what is in jack 1 why?
Try using the "source" or "input" button on your tv or remote control. That will cycle through any ports that are being used (hdmi, component, rca, etc)
Hope this helps!
Mar 09, 2011 | Televison & Video
How do i connect a virgin cable box with only scart output to a sony str dh810 AV reciever?
If your TV has audio outputs of any description, connect the V box to the TV via SCART and then connect the TV's audio output to your AV amp. This will allow you to use the amp to listen to the Virgin box's output being displayed on the TV. If you want to listen to mp3, connect the MP3 playing device to the AV amp. Select this source rather than t he source being used for the TV's audio. THe video output of the V box will still be displayed on the TV while you use the amp to play audio sourced via a different input on the amp.
Feb 03, 2011 | Televison & Video
How do i clean lg flatron W1952TQ screen?
According to the Owner's Manual (http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W1952TQ-TF.AUSMAPN&matchedModelCode=1000004017&searchEngineModelCode=W1952TQ&initialTab=documents&targetPage=support-product-profile#), unplug it from its power source, then wipe it with a slightly damp (not wet) cloth; & don't spray the screen with an aerosol because the overspray could cause electrical shock. I suggest that with it unplugged from its power source, use monitor wipes (available at most office supply stores). Then plug it into its power source away from souces of water, & you're done.
Oct 12, 2010 | LG Computers & Internet
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Power problem
Remove back, reseat all connectors. It is a mechanical interrupt to the relay board causing the problem.
Nov 15, 2007 | Initial DTV-172 17 in. TV/DVD Combo
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
