Question about Manfrotto (701RC2055MFV) Tripod
Base plate release lock
The lock for the base plate release on my Manfrotto tripod appears to be frozen. Can I use a some kind of lubricant to loosen it? Or is there another technique?
  • gavinobrien2 Jan 15, 2009
    Thanks for the considered advice. It helped me to remove the telescope from the tripod which I have now sent away for repair (under warranty).
    Novelist:
  • 121 Answers
Gavinobrien2,
Hopefully the camera isn't mounted. If the plate is bound because it is misaligned if may take some serious twisting. If it was cranked really tight just back it off carefully, you shouldn't need any type of lubricant or solvent based for seized or rusted metal parts, the release is sort of a cam it can get dust, grit or decal residue that might cause it to be tough to open. If the camera isn't a factor you can spray some compressed air (the can type for computers) which is super cold, directly on the cam to shrink it slightly then give it a crank - wear gloves and don't spray your fingers it can freeze your skin. If you are not comfortable doing that take it in to a camera shop and they may just do it for you. (tip - establish a good relationship with a reputable local camera shop by supporting them and buying your equipment from them, they know you and are willing to help with what they can or suggest the right equipment for you)
randy320sgi
Posted on Jan 12, 2009
Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
Jun 21, 2013 | Manfrotto Photography
How do I release a Manfrotto 501HDV head from a tripod
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Oct 27, 2012 | Manfrotto 503HDV Head and 351MVB2 Tripod...
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
The plate is stuck on the head of my 804rc2, maybe in backwards?
Yes, it would be really hard to put on and equally hard to get off. Make sure the safety lock is release and a flat blade screwdriver should pop off the plate once the primary lock is released.
Jun 30, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Hi,I have aManfrotto 458B and on one of the legs the quick release mechaniism isnt releasing have used lubbrication oil but as yet this does not seem to be working.
Because of the way the locking mechanism works inside the tripod I would recommend that you send the tripod back to Manfrotto / Bogen for repair. None of the parts inside the legs should be oiled, as the lubrication from the factory is enough. The parts not working is a symptom of a part being damaged or defective.
Manfrotto Distribution / Bogen Imaging Company
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Jan 17, 2010 | Photography
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Manfrotto (701RC2055MFV) Tripod Logo
195 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
