LCD TV Fault
Setup a 32LG7000 LCD yesterday evening. After about 20 minutes the screen started to "roll up" into increasingly narrower bands with varying "hues" eg green blue pink.Could this be a simple interference problem or a fatal flaw in the equipment.many thanks
  • stu1959 Jan 10, 2009
    Thanks for sharing your expertese.
    Should they really be that bad. I've only had the set for less than 24 hours?
  • 5,138 Answers
Pull back OFF look for bad capacitors if they are puffed up on top they are bad so replace them at same (UF) the voltage can be higher .for example if it is 220uf it has to be 220uf ,if 25volts it can be 35v.
Posted on Jan 10, 2009
  • ladywinn
    ladywinn Jan 10, 2009
    Well if its that New and you are already having problems take it back to store and get another one .
How to fix a led tv that has vertical lines around 5 minutes after turning it on then disappears when the tv has warmed up?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 28, 2016 | Samsung Televison & Video
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Sep 22, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
My monitor randomly turns itself off.
It is the monitor - go to dell thread here
Jun 03, 2009 | Dell E228WFP LCD Monitor
LCD screen looks like bad TV reception
if the display returns to normal when you press the bezel at on end means there is a bad connection to the inverter behind the bezel itself or the inverter is ready to give up the ghost.
you can attempt to dismantlethe laptop and remone the lid or in some cases just unscrew the bezel and remove the plastic cover, the inverter is at the bottom of the display you can't miss it
hope this helps
Nov 18, 2008 | Acer Aspire 5601WLMi Notebook
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
