Question about APC SmartUPS RT 3kVA Rackmountable UPS SURTD3000RMXLT UPS System
Apc 3kva ups is not working at 260 volts - APC SmartUPS RT 3kVA Rackmountable UPS SURTD3000RMXLT UPS System
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Try to do some calibration, but my question is why you need to plug the UPS on a 260 Volts??? which country you're from???
Posted on Feb 20, 2013
APC SURTD3000XLI UPS error light, 2 battery lights no output
check the fan in the back .... try to replace if damaged
Nov 13, 2013 | APC Smart-UPS RT 3000VA UPS System
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
Nov 13, 2013 | APC Computers & Internet
Have a APC xs-900 that indicates overload and there is nothing plugged into it. New battery did not help.
change the internal fan its a 18-24V type change it with a ball bearing type and yes a 12 volt will also work, with 120v input fine and under medium load the fan is only supplied with about 15 volts and only reaches 24 volts if the load shoots up or there is a power fail situation
Sep 09, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
3 fase 3 kva online ups invertor price & capacity load
Hello Santosh,
A 3 Phase 3KVA backup solution is outside the realm of an off th shelf solution. It would be best if you were to contact a manufacturer directly, as configuration and price depend heavily on your loads (continuous and instantaneous), battery capacity (usable time while AC is offline), mounting space available, rack configuration, just to name a few.
American Power Conversion (APC) is able to provide a solution that you require. You can contact them at 877-272-2722 in the USA, otherwise, consult apc.com and check the contact us link at the bottom of the page for alternative numbers.
Aug 27, 2010 | Electronics - Others
How Icalculate the back periode of ups?
look at back of ups, it will have rating plate
eg
230V 3000VA
pf= .7 2100WATTS
72V DC
in this case we have a 230Volt 3kVA ups at .7power factor giving a total of 2100watts of power.
batt is 72Volts DC
ups on bench, batt at full charge with lamp load, usually I connect 75% load eg 1575 Watts, then fail supply and time batts to batt alarm point.
recharge and test again.
can be done with any size ups, other way is to put in data into makers web site and they should give approx batt times for different loads.
Sep 07, 2009 | APC Smart-UPS RT SURT6000RMXLI (APC9672)...
Computer goes off peroidically. Computer is plug into the APC Back-UPS Pro
Ensure proper input voltage coming in the location.
Ensure the working condition of the UPS Button switch.
If this APC UPS is 2 to 3 years old, better replace the Battery 7 Volts - 1 Number and check the problem.
If the problem persists, Please contact local authorized UPS Dealer Engineer to settle this issue.
Jul 16, 2009 | APC Back-UPS® CS 500 UPS System
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Wanted: Circuit Board Repair APC UPS + other makes.
lol quite tempting. you can send it to me in singapore lol. Hi Andy, i assume theres a lot of UPS tech and Engineers in your area. or UPS service center. Good luck...
Jun 29, 2009 | APC Smart-UPS UPS System
APC UPS no power
The unit might have a dead battery, blow fuse, or a bad board.
Your best bet is to talk to an APC rep. Worst case, APC has a trade in program, and can give you a discount on a new one.
Good luck.
Try Chatting with an APC Support agent online.
Here is their direct link:
http://www.apc.com/support/chat.cfm
Chat with a Support Agent
Chat with Support for immediate assistance with your APC Back-UPS, Cable, Surge Protection, Notebook and Mobile Device accessories and products. Agents are available Monday through Friday from 8:00 a.m. to 8:00 p.m.
Feb 07, 2008 | Computers & Internet
APC SmartUPS RT 3kVA Rackmountable UPS  SURTD3000RMXLT UPS System Logo
85 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
