Question about NAD T753 Receiver
U 201 damaged where to buy
After 3 minutes warms up &malfunctioned
    Sergeant:
  • 344 Answers
Take it into a audio repair shop.
Posted on Nov 27, 2012
Merc E320 cdi cuts out on first few mile from cold 3 or 4 times
Throttle control sensor is where i would start.
Mar 16, 2017 | Cars & Trucks
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
Harley wont start with choke on,but can start it with choke off
Hi Cully, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Jun 03, 2012 | 2001 Harley Davidson XL 1200 C Sportster...
2002 mirage tranny delays shifting does not slip.Tranny fluid is full.Has 150,000 miles on it.
Mitsi transmissions are programmed for smooth gear changing and a brief delay is normal.
However, if the duration of the delay exceeds 2secs, then there is an internal problem with the transmission.
You need to run the diagnostics on your vehicle (the PCM controls both Engine + Trans electronics) which will determine where the fault is ocurring.
Most likely causes can be:
- Abnormal underdrive clutch pressure
- Malfunction of the underdrive solenoid valve
- Malfunction of the inderdrive clutch
- Malfunction of the valve body (which houses all the valves & soleniods etc)
- Malfunction of the idle position switch
Your Mitsubishi dealership can use their MUT-II scan tool query the solenoid.
Fluid - condition of fluid is critical for acceptable operation:
1) ONLY USE MITSUBISHI ATF FLUID - never use other brands.
2) Check fluid colour - must be nice RED colour. If black, then fluid is bad - change fluid.
3) If fluid smells burnt, then fluid should be replaced (burning smell can be a sign of internal damage).
4) Fluid level should be checked while trans is warm & idling in Park.
5) NEVER overfill the trans - overfilling can cause the excess fluid to foam, causing shifting problems.
6) Although manufacturer recommends changing fluid every 70,000 miles, it is always safer to maintain clean fluid by changing every 30,000 miles.
Cheers,
"If this has helped you in any way, please rate this solution or kindly leave me a testimonial"
May 12, 2011 | 2002 Mitsubishi Mirage
Display reads abs malfunction and tcs malfunction any suggestions
Best to get diagnostic codes to determine fault location, you can check the ABS toothed rings on cv joints for damage or corrosion first, sometimes they split an can cause tcs & abs fault
Apr 26, 2010 | 2004 Saab 9-3
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emission system codes
P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0171 - Fuel System Too Lean - (Bank 1)
P0446 - Canister Close Valve Malfunction
P1191/P1193 - Limp Home Valve - Low RPM
Before replacing the catalytic converter (bank 1 next to the firewall, Bank 2 is near the radiator), you'll want to verify it is bad (most likely is it sinse you also have a 'lean' code for Bank 1 - probably clogged). This can also cause misfires and engine stumble (low RPM) that's probably where the 1191/1193 occurred. The final DTC, P0446 - Canister Close Valve Malfunction, could be the valve itself, or the wiring between it and the PCM. Check the connector & pins for any damage/corrosion.
Hope this helps
Mar 30, 2009 | 2001 Hyundai XG300
Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Nov 25, 2008 | Audio Players & Recorders
Malfunction light on Jura E75
I just called the company with the same problem today. They will fix your machine for free. They have recalled this machine. Call them and they will tell you what to do. 201-767-3999
Nov 17, 2008 | Jura Capresso Impressa E75 Espresso &...
My espresso machine
can ask the service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700--Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Apr 18, 2007 | Dualit 84024 Espresso Machine
NAD T753 Receiver Logo
51 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
